![]() | Home > In Car Electronics (L322) > Bizarre amp issue |
jameshill Member Since: 15 Jul 2019 Location: Manchester Posts: 20 ![]() ![]() ![]() |
Hi everyone, hope you're all good.
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Hi James,
Ah, apologies, fixed the link: https://ebay.us/BOTcap
OK I thought that was the unit you were referring too.
Yes, I agree, but is it then sending the correct signal to the amplifier (silver box) to turn on? !!
Ooooh, interesting. Thanks!
Not had any luck here. Bought this cable off eBay to see if I could recode the DSP using the details below, but couldn't get it to connect to Navcoder or NCS Expert. Not sure if anyone has ever had any luck connecting to an L322 with either of those? Followed loads of different instructions and just wouldn't connect, even though it would be recognised fine by the BMW INPA application.
Think i'll try buy a replacement amp from the same car instead of a BMW one, surely that will work ![]() |
You'll be needing I-Bus I think.........
Interesting, will take a look!
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
ive currently got the seem beeping noise as you had pal and my head unit is doing the square route of sweet FA , think im going to look at what you did initially and see if I can at least coax some life into it |
Could I hell get this to work, ended up biting the bullet and shelling out for a replacement amp pulled from a Land Rover instead for about £160. Works a treat. |
