Home > Maintenance & Mods (L322) > 4.4 TDV8 Blown inlet manifold
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
Hi
the passenger side inlet manifold has split on my 85,000 mile 2011 4.4 TDV8, so I assume the Drivers side will do the same, so I will change them both, which does not look like fun.
Is there anything else worth doing while i am in there, based on what other failures people have seen on these?
Post #521777 15th Jul 2019 11:47am
Baltic Blue
Good luck Thumbs Up Thumbs Up
Please add lots of pictures to this post.
Have the oil cooler gaskets already been changed ?
If not, £20 for the two from Dan.
Where has it split ?
Post #521778 15th Jul 2019 12:05pm
Trantorman
its split round the joint the plastic, just the same as every other JLR manifold's do, my 3.6 did this my 3ltr Disco has been the same, shame they cannot make a decent job on these parts.
Thanks for then steer on the gaskets, they have been done previously.
I am not much of a pictures and post guy, I have always admired those that can and do.
But I will post back the out come.
Post #521781 15th Jul 2019 12:45pm
GraemeS
You might take some consolation from knowing that there has been only 1 revision of the 4.4's inlet manifolds and that your vehicle being MY11 very likely has the early versions.
Post #521818 15th Jul 2019 8:53pm
Trantorman
thanks, that's good to know,
passenger is off, injectors all came out with no real problems, drivers side is not in stock, so it will be a future job once I receive it.Passenger side should arrive e today and hopefully back on the road tonight.
Post #521856 16th Jul 2019 5:52am
Maxwell-Auto
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Re: 4.4 TDV8 Blown inlet manifold
Trantorman wrote:
Hi
Post #643716 23rd Sep 2022 2:54pm
Dolphinboy
@Trantorman
I had exactly the same (pax) side go 2 years ago. The part has been upgraded so make sure you get the newer version! the old one couldn't stand the pressure of both turbos and was inferior quality so split.
Great you can do it yourself. Mine cost £1600. only did one side and it is running perfectly 20,000 miles later. I think they renewed the injector lines (or at least they all had to come out hence the big labour cost).
here's the bill
Post #643720 23rd Sep 2022 3:13pm
JayGee
What year was the upgrade? 2012 TDV8 Vogue (L322)
Post #643723 23rd Sep 2022 3:19pm
Maxwell-Auto
I also have a 2011 TDV8 4.4 Range Rover in my Stable
Under 100k miles and services with care every 5k miles.
The Inlet manifold on the near side (UK) cracked at the interface of the manifold and down the side of the gasket.
The crack as shown is a clear failure of materials and judging by the number of reported faults by others, I was promoted my engineers to refer this to Jaguar Land Rover.
I had the breakage inspected by a Local Land Rover dealer for verification at JLR Customer supports request and they verified that it was a material fault.
However JLR has refused to contribute to either the parts or labour. As a LR owner for over 45 years and a stable of 5 vehicles I've more then demonstrated my loyalty to brand.
A plastic inlet manifold is about as secure as a chocolate teapot and when the specification is "not fit for Purpose" the second call I will make is to my lawyer.
While not a warranty matter, its an opportunity to demonstrate goodwill, but that's a very rare commodity.
Question: Has anyone else reported this fault to JLR ?
Has anyone obtained a recall notice ?
Has anyone been compensated for this "Negligence in Specification" ?
Would anyone be interested in joining me in am action to reclaim costs?. Thumbs Up
I just hate the way materials have become so sub standard. !
Trantorman wrote:
Hi
mikeyp wrote:
Post #643728 23rd Sep 2022 3:40pm
Dolphinboy
I'd gladly support your case to get my £1600 back! keep in touch.
Post #643729 23rd Sep 2022 3:44pm
Dolphinboy
I think they had fixed it for the L405 coming out. (2013?)
Post #643730 23rd Sep 2022 3:45pm
garyRR
I'm surprised at a bill of £1,600.
When they had gone on my 3.6, which is an even less accessible engine, it cost me £800 to have both sides done (although this was gaskets, not split manifolds), inclusive of labour, parts and VAT. 2015 Range Rover Autobiography 4.4 SDV8
Post #643731 23rd Sep 2022 3:54pm
Maxwell-Auto
Thanks Everyone
I will not let this matter drop
There are far too many failures to just swallow the entire cost of this dreadful material negligence.
The more that we can co join the better as the motoring ombudsman and USA consumer units will weigh in to support
I am lucky that my son is a builder and restorer of Classic Range Rovers, however with a full order book for 3 years getting time on the lift is like hens teeth
I have great local dealer too that I've been doing business with for 30 years, and they are disgusted that JLR are refusing to assist.
Thanks Again for the responses.
[img]
[/img]
Post #643735 23rd Sep 2022 4:11pm
Dolphinboy
When they had gone on my 3.6, which is an even less accessible engine, it cost me £800 to have both sides done, inclusive of labour, parts and VAT.
Gary, 6 hours so £600 labour, £215 for injector kit x3. plus ancillaries. This was only 2 years ago. I wish it WAS £800 all in! Shocked
Post #643741 23rd Sep 2022 6:11pm
GraemeS
Revised part numbers are shown in Microcat 2012 from the start of the L405. However there were a few 4.4 engine upgrades starting with VINs from early 2012 so perhaps the revised parts were introduced around the same time or at least before the last of the L322 rather than only for the first L405.
Post #643755 23rd Sep 2022 8:57pm
