![]() | Home > In Car Electronics (L405) > SOTA |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
...but now I can!
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Did you have to have a sim or can it use WiFi when parked up? Current: RR L322 2010
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
How did you get topix to show it? |
Aldogt3 Member Since: 04 Mar 2018 Location: Zagreb Posts: 15 ![]() ![]() |
Thanks to Q86ARR |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 ![]() ![]() ![]() |
Finally my SOTA has been completed. It would not work via the screens ( as it should ) so had to go into the Stealership.
Assume they didn't charge you? Current: RR L322 2010
No, no charge. And I would have definitely NOT paid if there was. |
I still haven't got access, but like most others, Q86ARR has been brilliant and used his access to enable the updates - I am now on 19A4 (the latest) thanks to his efforts. It seems that once an update is enabled, SOTA works fine, although I get the impression that each update needs a new permission, which is daft! As a general comment, maybe the way forward is for everyone to contact their local dealer and demand they go online to enable updates for their car. |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 ![]() ![]() ![]() |
This very thing was discussed on the iPace forum in May, the reply a Norwegian member had from JLR was "In regards to SOTA, JLR does not push out updates to all vehicles. Currently, this is done on a per-vehicle basis by the dealer." - from our collective experience it does not seem to have moved beyond this.
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 490 ![]() ![]() ![]() |
Agree Q86ARR has been an absolute star for helping us all. The LR garages have no clue.
For Landrover, just one bug fix but quite a critical one if you are using your phone with CarPlay enabled:
Ahh, that’s been happening to me but thought it was my wife’s phone! That’s great! 2017 Range Rover Vogue V6 Diesel
And to think there was a bulletin (SSM74417) for this issue which blamed Apple |
The annoying thing with SOTA updates is it seems it isn’t automatic and the updates have to be manually applied. 2017 Range Rover Vogue V6 Diesel
