Home > Technical (L322) > MIL light coming on ??
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
When I got my car last year the light was on. Switched car off left overnight and light never came back on. Some 4 months later the light came on this saturday, went off later in the day, but has remained on ever since.
I've had a long 'search' to see if there are any clues on what to check but couldn't find much at all.
Q : does the car need to be looked at by a garage with a plug in reader to tell me what's wrong or are there some simple check I can do? Its a 4.2 S/C model.
thanks in advance.
Post #52127 28th Feb 2011 1:37pm
dan_uk_1984
You can buy a reader yourself for under £30 that plugs into your laptop and will tell you the code - you can then lookup the problems relating to this code.
Without knowing the code there's not a lot you can do unless you have other symptoms.
With a SC I really wouldnt risk driving it round with the light on.
D
Post #52133 28th Feb 2011 1:53pm
bozmandb9
Re: MIL light coming on ??
thanks in advance.
When I test drove mine the light was on. I got it converted to LPG before I picked it up, and when I picked it up the light was off. Short whilst later and the light was on again. I got the code read, and it said that the car was running lean. I took it back to the LPG place and they had a fiddle with it, and the lights now off.
What the LPG place said was that the S/C is sensitive to fuel trim (with or without LPG), and this is a common reason for the MIL coming on. I guess that makes sense on a Supercharged car.
Best thing would be to take it to a specialist who you can trust, to read the car and make any necessary adjustments via the computer.
Out of interest, do you have any gearbox issues? Range Rover-less at the moment - Pining!
Post #52136 28th Feb 2011 2:28pm
duka
no gearbox issues (well that I've noticed!)
Thanks for the advice, will try and locate a reader now - any clues where to buy other than ebay?
Post #52181 28th Feb 2011 5:58pm
dan_uk_1984
Erm, eBay Smile
Post #52182 28th Feb 2011 6:00pm
you can get a bluetooth obd2 unit with software for about £22 delivered from ebay. ... - .- -.
Post #52183 28th Feb 2011 6:02pm
duka
thanks for that, are they all the same (i.e. universal) is their a specific make etc - before I buy one?
Post #52270 1st Mar 2011 8:16am
the 'em357' [or sounds similar] seem to be the ones to get, but they are probably all made in the same chinese factory.. ... - .- -.
Post #52271 1st Mar 2011 8:26am
bozmandb9
I bet when you get the code read it will relate to fuel trim, either running lean or running rich. My not pop into any friendly garage with EOBD kit and get the code read? Range Rover-less at the moment - Pining!
Post #52597 2nd Mar 2011 7:48pm
duka
Key point in my area - "friendly garage" doesn't seem to be one, £75 is the best to just plug it in to tell me what the error code is extra!
I've ordered a ODBII reader/scanner should be here early next week, next problem will be if it is the fuel trim - getting someone to adjust into the correct range!
btw I would NEVER go to my main dealer for any support or service, they are hopeless Big Cry
Post #52638 3rd Mar 2011 8:30am
