Home > Technical (L322) > MIL light coming on ?? |
duka Member Since: 11 Jan 2011 Location: uk Posts: 145 |
When I got my car last year the light was on. Switched car off left overnight and light never came back on. Some 4 months later the light came on this saturday, went off later in the day, but has remained on ever since.
28th Feb 2011 1:37pm |
You can buy a reader yourself for under £30 that plugs into your laptop and will tell you the code - you can then lookup the problems relating to this code.
28th Feb 2011 1:53pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
When I test drove mine the light was on. I got it converted to LPG before I picked it up, and when I picked it up the light was off. Short whilst later and the light was on again. I got the code read, and it said that the car was running lean. I took it back to the LPG place and they had a fiddle with it, and the lights now off. What the LPG place said was that the S/C is sensitive to fuel trim (with or without LPG), and this is a common reason for the MIL coming on. I guess that makes sense on a Supercharged car. Best thing would be to take it to a specialist who you can trust, to read the car and make any necessary adjustments via the computer. Out of interest, do you have any gearbox issues? Range Rover-less at the moment - Pining! |
28th Feb 2011 2:28pm |
no gearbox issues (well that I've noticed!) Thanks for the advice, will try and locate a reader now - any clues where to buy other than ebay? |
28th Feb 2011 5:58pm |
Erm, eBay |
28th Feb 2011 6:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
you can get a bluetooth obd2 unit with software for about £22 delivered from ebay. ... - .- -. Y. O. L. O. . |
28th Feb 2011 6:02pm |
thanks for that, are they all the same (i.e. universal) is their a specific make etc - before I buy one? |
1st Mar 2011 8:16am |
the 'em357' [or sounds similar] seem to be the ones to get, but they are probably all made in the same chinese factory.. ... - .- -.
1st Mar 2011 8:26am |
I bet when you get the code read it will relate to fuel trim, either running lean or running rich. My not pop into any friendly garage with EOBD kit and get the code read? Range Rover-less at the moment - Pining! |
2nd Mar 2011 7:48pm |
Key point in my area - "friendly garage" doesn't seem to be one, £75 is the best to just plug it in to tell me what the error code is extra! I've ordered a ODBII reader/scanner should be here early next week, next problem will be if it is the fuel trim - getting someone to adjust into the correct range! btw I would NEVER go to my main dealer for any support or service, they are hopeless |
3rd Mar 2011 8:30am |
