Home > General > A question about Diesels |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
After a few years of running a trouble free petrol RR I’ve taken the plunge and bought an L405 but it’s a diesel. I’m sure i’ve read somewhere that you need to allow the turbos to “cool down” before switching off after a journey (it might not be cooling down but you get the picture). On my arrival home I drive though our estate for about half a mile at 20mph - would this do it or do I really have to sit on my drive with the engine running for 5 minutes with the dog try to jump through the window .? Geoff |
6th Jul 2019 7:19am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
I honestly think you would struggle to work the Range Rover turbos hard under normal road conditions so I wouldnt worry too much about the cool down. Diesels run cooler than petrol turbo's anyway. My regime if for example Im towing my caravan and intend calling at a motorway service area I slow down to 50 mph a mile before the services, then the drive to the parking space will allow enough time for any cooling needed.
6th Jul 2019 7:44am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 540 |
Equally as important is to ignore the stupid modern fashion for extended service intervals for oil/filter changes and do it every 10,000 miles with good quality oil of the correct spec. Drives:
6th Jul 2019 7:47am |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
Unless the turbo has just been worked hard, I just take the time to close the windows and sunroof, turn off the radio, grab my phone and then turn the engine off. The 20 seconds or so that lot takes should be enough to dissipate any residual heat in the turbocharger bearings
6th Jul 2019 12:42pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Motorway petrol stations are the only time I leave mine running.
6th Jul 2019 4:14pm |
I went googling and found this:
6th Jul 2019 4:56pm |
The real problems are highly stressed petrol eg Cosworth Sierra this was a favourite. Give it some wellie and the turbo would glow bright red, switch off the ignition the residual oil is burned, the turbo still spinning and the oild fried rendering a mess of carbon. The inner parts of the turbo near white hot.
6th Jul 2019 5:15pm |
Interesting
6th Jul 2019 5:33pm |
The difference here is a) were diesel and b) were not to work it that hard so nothing to worry about. I helped my son develop his 1300cc Toyota engine, now produces over 400 bhp, the turbo on that was a nightmare. It now has a turbo timer, you switch off the ignition and can lock the car and walk away, the engine idles for 3 minutes. During this time it can only idle opening the throttle etc does nothing.
6th Jul 2019 7:56pm |
takes me back a few years - I had a Subaru Impreza with one or two modifications - that’s where I learnt to respect a turbo after a good thrashing.
6th Jul 2019 8:53pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3742 |
Normal driving is fine - it’s when you have been driving with your balls hanging out or towing a massive load when the engine and oil is really hot that it needs to cool down before shutdown - if you don’t in these circumstances the oil cooks on the turbo bearings and it’s curtains in a very short space of time. RR are usually fine - it’s high output diesels in Trucks and Tractors that must be idled after hard work.
6th Jul 2019 9:10pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Geoff, if you feel the urge to take your new car on a track day then YES, you need to allow the turbo's to cool before shutting her off...If you drive her like any half decent citizen then don't worry about the turbo's cooling! At anything under half throttle and 50mph your turbo's are only just ticking over sir... |
6th Jul 2019 11:37pm |
