Home > General > 2006 FFRR 4.2SC. What to look out for?
Arkle
Evenin' all.
I'm going to view a FF 2006 4.2SC tomorrow that has covered around 120,000 miles.
I've yet to own a Range Rover, so any advice on what to look, feel or listen out for would be greatly appreciated.
Thanks in advance.
Paul.
Post #282036 20th Sep 2014 10:27pm
ebajema
The engine oil to coolant cooler should be replaced (the early ones failed and engine oil and coolant mix) and the same type cooler is also used for gearbox to engine coolant, same problem. On my 2006 both failed within a month of each other.
Considering the age the suspension airbags are nearing their replacement point (since the front includes the shocks, not a bad thing). You are unlikely being able to inspect, on mine we could only see it once the struts were removed and the bags fully blown up (difficult since they were leaking badly). All the cracks were well within the folds.
The gearbox may have the 3-4 shift problem, we (RRPhil and some forum members) have tracked it down to a single solenoid in the gearbox Mechatronic so easy to resolve.
At this mileage the gearbox oil and filter should have been changed (100,000 miles actually).
These are a few of the "hot items" on the SCs.
Suggest to get all ECUs re-flashed with the latest software to eliminate any issues like Engine Management Light coming on for no good reason and gearbox ECU to be up to date.
Plus this one in the Wiki, thanks to Ryan.
http://www.fullfatrr.com/forum/post189410.html#189410 MY 2010 5.0 SC Galway green and sand interior!!
Post #282071 21st Sep 2014 9:34am
Jamoresby
Also this might seem very minor but make sure all the toys like venture cam, rear earphones and remote for the rear entertainment are present as although not a major issue why should you get an in imcomplete SC and also the spare wheel is a full size alloy the same as the rest etc and obviously a very thorough service history. Good luck ! Current
2014 BMW M3 F80 (Mineral White)
Previous -
2006 RR Vogue SC
2005 RR Sport HSE
__
On order 2015 RR Vogue (Yulong White)
Post #282115 21st Sep 2014 2:16pm
Sandyt
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Good tips those as I have all the bits and to me it shows how well the car has been looked after and cared for
Post #282121 21st Sep 2014 3:36pm
Arkle
Ebajema, jamoresby and Sandyt, thanks very much indeed for the information (I could only view on my phone but got the gist of most of it).
I viewed the car, and although I couldn't do any of the mechanical checks advised, I did notice that the gear changes were smooth and that everything works on the car. Venturecam and its accessories and also the headphones were all with the car.
However, (I have started a separate thread on this query, btw).
I wanted to test the acceleration and from a standing start I was a little disappointed.
I was expecting to be thrown back into my seat, but there was none of that!
I looked down at the clock to see when the car would reach 60mph and lo and behold it was travelling at almost 75!
Is my lack of a thrill from this experience due to the RR accelerating in a refined manner or am I missing something? It just didn't seem that fast.
When accelerating from the standing start, one thing I did notice was a whooshing air sound coming from (at a guess) the N/S front wing. Is this normal?
Thanks again for the advice. Thumbs Up
Post #282173 21st Sep 2014 9:20pm
hongkongphooey
Isle Of Man
I have an 06 4.2 SC and they are deceptively quick.
In comparison to previous cars I've owned that were turbo charged, it feels more refined, the supercharger is essentially linear in its power delivery as opposed to a bit of a sudden rush with a big turbo. Don't forget how much weight you're having to accelerate from standstill, 2.5 tonnes.
Where they really pay off is when up and running, they just keep going and going like they'll never run out of power. Which in the real world, is where you need the power (overtaking).
You should have taken a TD6 out for a blast first, then you'd have been impressed Thumbs Up
The noise you heard could have been either the supercharger, more of a whine, or the viscous fan if it was hot.
They're a lovely car, if you get one you'll not feel wanting for more. Yes there are cars, including the 5.0SC that are quicker, but the 4.2 is really quick enough.
Hope you find a nice one! Present* 2006 Santorini SC Vogue SE.
Gone* 2006 4.4 AJV8 Zermatt Vogue.
Gone* 2004 TD6 Bonatti Vogue.
Post #282179 21st Sep 2014 11:25pm
Arkle
Thanks, Number One Super Guy! Wink
It was never going to be a TD6. I'm not really a fast driver, but when there's a time and a place, it's nice to have some oomph. Razz I've had 7 Mercedes-Benz cars and vans and the turbo diesels (3.2 straight 6 & 3.0V6) have been super engines and never failed to put a smile on my face. I currently have an E430 V8 which surges pretty nicely too, so maybe I have to become accustomed to a smoother delivery with the RR. I'll be picking it up this evening, so I'll have a better chance evaluate it on my (most probably extended) journey home.
Thanks for the help. Much appreciated. Thumbs Up
Post #282183 22nd Sep 2014 1:53am
Sandyt
Good luck with the new vehicle good decision Thumbs Up Thumbs Up
Post #282193 22nd Sep 2014 8:20am
ebajema
The lack of "experience" when flooring the throttle is what it should be. On the 4.2 you can hear the supercharger making a bit of noise, the 5.0 is super quiet. It is scary how little you notice of the 400 BHP being unleashed (or 500 BHP on the 5.0) as you hit the throttle.
Opening the window and switching to a sport exhaust will give you more of the sound if you like Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #282194 22nd Sep 2014 8:49am
Arkle
Thanks Guys. Thumbs Up
Post #282197 22nd Sep 2014 9:09am
Greg66
2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Re: 2006 FFRR 4.2SC. What to look out for?
Arkle wrote:
Evenin' all.
Thanks in advance.
Paul.
Petrol stations.
(They're worth it though! Thumbs Up ) Range Rover 4.2 SC
AM V12VS
Porsche 991.1 Turbo S
Mini JCW conv
Post #282289 22nd Sep 2014 7:36pm
Another thing worth dong is getting the supercharger oil changed. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #286747 16th Oct 2014 2:13am
Arkle
Thanks KP. Thumbs Up
Post #286749 16th Oct 2014 3:16am
Nadijono
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Can you please show me which engine oil cooler to coolant you refering too , i had oil bubble up throught my coolant bottle.
My car didnt overheat or any white smoke indicTing headgasket. But i cant seem to find the engine oil cooler .
I immediately knew what you were refering too , can you please advise the part ni ber or location. I cant pm yet. New to the group
Post #520556 3rd Jul 2019 7:37pm
Nadijono
Is there an engine oil cooler , or just a oil filter housing ?
Post #520558 3rd Jul 2019 7:51pm
