![]() | Home > Technical (L322) > alarm going off randomly because car thiks bonnet is open? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
common problem..... so you could,
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Ah ok
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Had this with a disco 4. Not what you want to see when doing 70(ish) on the motorway: Bonnet open....... :O
Deffo not what you want to see on the motorway lol.
On the disco 4 (mine anyway) there were 2 latches, one each side, but only one had the sensor on so was easier on that to just replace the whole unit. A couple of bolts, remove the paperclip and insulating tape used to short the sensor cable out and then plug it in. Trickiest part was getting the release wire into the new latch from memory but it wasn't that hard either. Current: RR L322 2010
Ah ok sounds like it must be different to the l322 the. As I think that the latch just holds the bonnets closed on these and the sensor is a separate part .. Regards
sorry dazza, i meant disconnect it , not connect the wires together... ... - .- -.
New bonnet closed switch is only £18 so I’ve just ordered one.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Same issue here a couple of years ago, quick fix is to just stick a rubber pad or something onto the bonnet to ensure the switch is pushed down properly after just touching up the contact point on the bonnet that may have worn the paint away.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I put a rubber gromit on the plunger thing....made it artificially longer...no issues since.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
The bonnet open sensor is on driver side firewall near the brake booster.
SandyW Member Since: 30 Apr 2020 Location: Herts Posts: 22 ![]() ![]() ![]() |
Had the same problem with my 2012 Westie this weekend. Got a replacement switch and the new one seems to have a longer button by about 0.5cm vs the old one so hopefully that does the trick. |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
I had the same issue early in lockdown. I thought it was the battery running down initially, but it wasn't! I disconnected the connector on the back of the bonnet switch, bridged across with some wire and taped it up. No issues since. I will get around to replacing at some point! Rob 05 L322 4.2SC
