![]() | Home > Technical (L322) > Todays Suspension Fault Is..... |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Hi Guys,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Is it the one where drilling a hole in the brass vent plug solves I wonder? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Agreed -- simple place to start -- could save a whole heap of head scratching |
Please tell me more BMW i3 Electric Car
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35667 ![]() ![]() |
https://www.fullfatrr.com/forum/topic23038.html ... - .- -.
Done that now, see if its cured.
Yes, outlet indeed, hence when blocked, the gallery can't exhaust Current: 2011 FFRR Vogue SE 4.4 TDV8
Not totally true - the compressor can fail in a state where it also cannot vent. Brass exhaust or not. BTDTBTTS. Land Rover Addict
Oh I wasn't suggesting this is the answer, merely that if it is blocked it would be, and probably the easiest thing to try in an attempt to rule it out Current: 2011 FFRR Vogue SE 4.4 TDV8
Guys once again, this forum saves ££££'s. Took the filter off, not had a problem since.
Glad it helped |
Bang on the money Bushy, thanks.
