Home > Technical (L322) > Todays Suspension Fault Is.....
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Hi Guys,
I've had this fault twice now over the last month or so, any pointers?
RLM-Suspension
C1A13-64 (AF) Pressure does not decrease when venting gallery - Algorithm based failure - signal plausibility failure
( on 02-07-2019 11:13:04 at 219230 km )
Many thanks in advance. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #520320 2nd Jul 2019 10:56am
DrRob
Is it the one where drilling a hole in the brass vent plug solves I wonder? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #520323 2nd Jul 2019 11:11am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Agreed -- simple place to start -- could save a whole heap of head scratching Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #520326 2nd Jul 2019 11:25am
AJGalaxy2012
Please tell me more BMW i3 Electric Car
Post #520333 2nd Jul 2019 12:02pm
https://www.fullfatrr.com/forum/topic23038.html ... - .- -.
Post #520336 2nd Jul 2019 12:06pm
gavinn
I just took my brass vent plug off and threw it in the boot somewhere, works much better now, the occasional PSHHHHHH noise from the back but i can live with that.
Post #520338 2nd Jul 2019 12:13pm
AJGalaxy2012
Done that now, see if its cured.
I may have fried the compressor driving back from Belfast with a leaking airbag, if thats not cured it I'll get another compressor.
There didnt appear to be a lot of air going in via that filter, is it only an outlet?
Thanks for your help everyone.
AJG BMW i3 Electric Car
Post #520349 2nd Jul 2019 1:19pm
Bushy30
Yes, outlet indeed, hence when blocked, the gallery can't exhaust Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #520354 2nd Jul 2019 1:56pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Not totally true - the compressor can fail in a state where it also cannot vent. Brass exhaust or not. BTDTBTTS. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #520355 2nd Jul 2019 1:59pm
Bushy30
Oh I wasn't suggesting this is the answer, merely that if it is blocked it would be, and probably the easiest thing to try in an attempt to rule it out Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #520359 2nd Jul 2019 2:12pm
AJGalaxy2012
Guys once again, this forum saves ££££'s. Took the filter off, not had a problem since.
Thanks again all you, youre a great team.
Post #520764 5th Jul 2019 4:42pm
Bushy30
Glad it helped Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #520766 5th Jul 2019 5:25pm
AJGalaxy2012
Bang on the money Bushy, thanks.
Post #520781 5th Jul 2019 7:19pm
