Home > Maintenance & Mods (L322) > Where is my sump plug?
Further to my intention to give the RR an Oil change and filter service myself in the interim between proper services, the one thing I haven't yet found is which side the sump plug is on the TD6. Had a crawl underneath today and all I can see is plastic underbody panels, which I presume need removing first.
Having gone through the RAVE workshop manual there is no mention of these panels or the removal of them, or which side I will find the sump plug.
Also, is it absolutely necessary to lift the car on ramps in order to drain the oil? I used to do my old Land Rover on the driveway no problem, but it was on 750x16 tyres so there was a decent amount of ground clearance.
If I get some axle stands is this enough do you think?
Surely someone on here has done this before on a TD6? Discovery 4 HSE
Post #5192 26th Apr 2009 4:42pm
Don't know if this site will be any help Adam,
http://www.landroverclub.net/Club/HTML/Main_cheap_tricks.htm
Post #5194 26th Apr 2009 5:22pm
A good source of information thanks Mick, sadly, can't find anything on the L322 there. The maintenance procedures seem to be aimed at Series and Defender types, which is dead simple, cos you can see all the components as soon as you lift the bonnet. Discovery 4 HSE
Post #5195 26th Apr 2009 5:49pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
Insert image:
(alt+p)
Post #5198 26th Apr 2009 8:11pm
Jope,
Thanks but I already have that part of the workshop manual!
Trouble is, it doesn't state anything about the underbody plastic trays and their removal or which side to find the sump plug. Discovery 4 HSE
Post #5199 26th Apr 2009 8:32pm
jope
looks like left side seen from front
Post #5201 26th Apr 2009 8:43pm
Just to complete this post its the rear of the engine block on the left side when looking from the front. Discovery 4 HSE
Post #5399 5th May 2009 12:25pm
