![]() | Home > Maintenance & Mods (L322) > Dreaded wheel arch rust lower front of rear arches |
200AD Member Since: 17 Apr 2019 Location: Leicestershire Posts: 18 ![]() ![]() ![]() |
Hi, I have a 52 plate with tinworm in the same place but I think yours is a less advanced state than mine.
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 ![]() ![]() ![]() |
My 2006 looked exactly like that. You need to remove the plastc sill cover, more is waiting for you there. I used a mini sandblaster and had to weld some patches. I used 2-pack epoxy primer and polyurethane Topcoat. This is not readily available in Norway as a car product, but if you go to a boat shop you can buy it off the shelf. In one place I did not get it good enough and it has reappeared. I also had the inside of these areas treated. It is 13 years late, but better than doing nothing. To gain access for anti-corrosion treatment there are rubber plugs inside the wheel well.
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
It ridiculous how they rust like that. Mine was the same. I can't remember the last car I owned that had rust! |
I'm pretty sure that if I stand close enough I can here the corrosion fizzing away on mine! |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Thanks Ian and others.
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
The end of the sill under the plastic sill trim cover, is likely to have rotted far worse than the bit you can see. By this I mean you'll have an area which will either be holed or will crumble the second you touch it.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
mine had corroded under the cover and side skirt,all was cut out and replaced including the arch,don't cut corners or paint over it it wont last |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
![]() Please let me know if my comments upset you, I may wish to upset you again. |
Bilt Hamber........excellent stuff. David Please let me know if my comments upset you, I may wish to upset you again. |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
I'm doing mine at the moment. Using a grinder with a polycarbide disc to clean the rust up and then will be using some vactan rust converter to stabalise the metal. Then some zinc 182 primer and for the non visible areas and behind the covers some stone chip paint and finally top coat and clear coat.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
I had same issue looked everywhere for some repair panels nobody does them so we sanded back to bare metal treated it and sprayed it all with the correct materials it didn’t last a month before bubbles appeared again as rust penetrates from inside to outer skin. We did this three times using different rust treatments in the end we had the effected areas cut out and done properly it’s the only way to do it properly as my passenger side wheel arch lip had actually started to break away these cars rear arches are a crap design end of. I have had no problems with Range Rover sport rear arches just the L322🙈 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Those of you who have cut out and welded material in, what thickness of material did you use?
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Following this as mine are in a similar, if not worse state.
