Home > Maintenance & Mods (L322) > Yes, I did buy a lemon |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
So I just took the TDV8 for a full service and asked them to look at the restricted performance fault and the fluttering noise.
24th Jun 2019 2:23pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Could be worse.
24th Jun 2019 2:33pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
Could be worse!
24th Jun 2019 2:41pm |
Just had a quote to do the broken stud. £1200 all in. They said they will have it for three days.
24th Jun 2019 4:22pm |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 |
The manifold repair sounds cheap compared to when one had to be replaced on mine!
24th Jun 2019 5:17pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Definitely explains your fault anyway Andy, Diesel noise getting louder as you drive etc. Manifold expanding with the heat.
24th Jun 2019 8:48pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
Hi Paul what was the outcome when you had symptoms of shudder etc was it an injector or wiring loom at fault.
24th Jun 2019 9:24pm |
Mine was an injector. I used an IID tool measure the injector values which showed an issue with injector number 1. I then tested the loom (easy to do with a multimeter) which was ok so swapped the injector.
24th Jun 2019 9:30pm |
Ah right ok did you measure the reads at standstill idle or at a steady drive. My reads seem ok at standstill but at a steady speed of 30MPH CYL 6 is showing between 8 to 10mm3 fluctuating where as CYL 1 to 5 read 655mm3. Also i get quite a bad shudder in reverse and the shudder is more noticable when driving under light throttle. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
24th Jun 2019 9:34pm |
At tick over. Mine all read between -2 - +3, apart from injector number 1 which was +7.
24th Jun 2019 9:38pm |
Ok cheers Paul Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
24th Jun 2019 9:40pm |
The weird thing is, since it was serviced, it hasn’t faulted once! I saw 30mpg on a run as well. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
29th Jun 2019 7:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
A lot of work as all the injectors need to come out to change the inlet manifold/rocker cover... Warranty will require new seals and pipes which run into hundreds more! Just be aware... |
29th Jun 2019 10:49pm |
