Home > Technical (L322) > Test pulse flashing on LED headlights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35439 |
depends to where your halos are connected to...if the side light circuit then switch off the hot/cold monitoring to that.. ... - .- -.
17th Jun 2019 2:57pm |
to make sure the incandescent bulbs are functioning ok , on start and also when lit.. ... - .- -.
17th Jun 2019 3:10pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
Ahh right ok so I suppose a function that isn't needed as if there was any issues a fuse would blow anyways! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
17th Jun 2019 3:15pm |
RobWheatley Member Since: 10 Mar 2019 Location: Yorkshire Posts: 37 |
Where did you get your Halo's from if I may ask?
17th Jun 2019 6:43pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
Rob, if the question is to me, here is a Vid of my lights. You will see on start up the led side lights flash with the test pulse, however, the LED headlights wired up through a relay Don't. The DRLs run through a voltage sensing relay which turns them on when the cars charging hits 13v and off a few seconds after the engine is off. There is another box that switches them from white to orange with the direction flow. They don't look that bright in the video but trust me they are very bright. I also have a LED lightbar and 2 small lower bars which are turned on and off by a remote control relay. The controller is like a key fob so I can turn them on an off from in or out of the car.
20th Jun 2019 7:48am |
Thanks for that, looks great, Loving the drl/flow lights, not sure if they would be easy to fit to mine, they are the later headlights with plastic lenses, don't know how easy they come apart.
20th Jun 2019 8:57am |
