Home > Technical (L322) > Test pulse flashing on LED headlights
depends to where your halos are connected to...if the side light circuit then switch off the hot/cold monitoring to that.. ... - .- -.
Post #518772 17th Jun 2019 2:57pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Ok cheers Stan yes they are wired into the side lights. What is the purpose of the hot and cold monitoring. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #518775 17th Jun 2019 3:03pm
to make sure the incandescent bulbs are functioning ok , on start and also when lit.. ... - .- -.
Post #518778 17th Jun 2019 3:10pm
jaysta10k
Ahh right ok so I suppose a function that isn't needed as if there was any issues a fuse would blow anyways! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #518781 17th Jun 2019 3:15pm
RobWheatley
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Where did you get your Halo's from if I may ask?
Rob 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #518807 17th Jun 2019 6:43pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Rob, if the question is to me, here is a Vid of my lights. You will see on start up the led side lights flash with the test pulse, however, the LED headlights wired up through a relay Don't. The DRLs run through a voltage sensing relay which turns them on when the cars charging hits 13v and off a few seconds after the engine is off. There is another box that switches them from white to orange with the direction flow. They don't look that bright in the video but trust me they are very bright. I also have a LED lightbar and 2 small lower bars which are turned on and off by a remote control relay. The controller is like a key fob so I can turn them on an off from in or out of the car.
Probably not to everyone's like but I am happy with them.
https://www.youtube.com/watch?v=xIY4r71ynoA 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #519068 20th Jun 2019 7:48am
RobWheatley
Thanks for that, looks great, Loving the drl/flow lights, not sure if they would be easy to fit to mine, they are the later headlights with plastic lenses, don't know how easy they come apart.
For the side lights flashing, powerful UK do relays that would do that. 2010 L322 3.6 TDV8 Vogue Stornaway Grey
Post #519079 20th Jun 2019 8:57am
