![]() | Home > Maintenance & Mods (L322) > Illuminated sill trim repair |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
I don't have one on my sc but I have these on my m6 and the are a terrible design. Water penetrated through the tread plate over time and short the light tape out and it's game over. On those there is a dig to use a heat gun to separate and use some new light tape. Current stable:
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 373 ![]() ![]() ![]() |
Can get a 12v, 1.5 w led fibre optic light source and side skirt glow optical fibre cable that comes in varying sizes from 3 to 10mm might give it a try. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Found the url I did it on mine
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Can't see the file DYI_ M6 Illuminated Door Sill Mod.pdf without a login Dan, any chance you could post somehow?
Found it:
Sure will grab in a bit Current stable:
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Mine were like that - I ended up buying a replacement set, but the light is still pretty feeble in them, especially if you have LED puddle lamps.
I have downloaded it but how can you upload files on here I have only ever done images? Current stable:
