Home > Technical (L322) > Headlight woes - halogen main beams on when they shouldn't
ArtFF
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Good evening all. Been browsing for a while as I was researching the technical aspects of RR ownership and just signed up.
I have a very strange issue which I will do my best to explain properly.
If I turn on my sidelights or dipped xenons with the indicator stalk in the "default" position, my halogen main beams engage. There is an accompanying blue icon on the dash.
Pushing the stalk forward disengages the halogen main beams, the light goes out but obviously my xenons are now in "main beam" mode.
So at night I currently have a choice between blinding road users with the halogens or xenons...
I understand the function of the halogens is for flashing purposes as xenons take a while to warm up but I'm at the point where I'm considering pulling them out altogether.
I have a done a battery reset to no avail and with my OBD device have cleared all faults. When I engage the indicator stalk at all, one reappears in the Lighting module - Flasher signal switch line short circuit to ground.
Now this makes sense but the problem is I don't know where this short could be. Is the indicator stalk a likely culprit? If so, how simple is it to replace?
Many thanks Smile
Edit: My profile is mucking about apparently - 2002 V8 Vogue
Post #518929 18th Jun 2019 5:14pm
fill your car profile in so we know what year/model you have .. ... - .- -.
Post #518930 18th Jun 2019 5:27pm
ArtFF
It's all there, not sure why it's not appearing
Post #518931 18th Jun 2019 5:29pm
select the colour Thumbs Up ... - .- -.
Post #518934 18th Jun 2019 5:59pm
ArtFF
D’oh apologies... fixed
Post #518936 18th Jun 2019 6:02pm
ArtFF
Doing some more reading I'm 99% sure it's the indicator stalk.
The LCM detects the flasher function according to the ground. So if that's shorting as the code suggests, I imagine the LCM thinks I have the flasher pulled back permanently.
Ordered one off eBay, will update when I swap it over. Any guidance on this would still be much appreciated Smile
Post #518945 18th Jun 2019 6:54pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Not done it myself but had the steering wheel cowling off a few times for the reach motor. The leather gaitor clips off and sides back and underneath the steering column is 3 or 4 torx bolts holding the plastic cowls together. I seem to remember there are 2 different sizes - T25 & T27 needed (don't quote me) and you'll need these to be long handled as they are quite deep and a normal screwdriver length won't reach. You should then be able to see the indicator stalk and switch it out. I suspect someone else will be along if there is any special needed to remove the actual stalk Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #519002 19th Jun 2019 12:52pm
ArtFF
Brilliant thanks Nick. I had a look underneath and saw the holes for the screws. I have torx bits, lets just hope my socket extension is long enough. Replacement stalk here tomorrow hopefully.
Post #519023 19th Jun 2019 3:35pm
ArtFF
Update... plugged in the new stalk, same problems. Either LCM or wiring has gone wonky I guess
Post #519138 20th Jun 2019 5:24pm
ArtFF
Found an LCM from the same year on ebay for buttons so figured worth a try.
Problem solved! I have the mileage discrepancy dot now but rather that than wonky lights.
Post #522889 26th Jul 2019 4:08pm
