![]() | Home > Technical (L322) > Westminster Deployable Steps |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Hi Brian,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
the button is not a default fitment...i suspect that the steps were taken off for some reason...check underneath for loose plugs/wiring around the front and also there you can also see if step brackets were fitted in the past.. ... - .- -.
Welcome... To add to above, if you remove the trim panel next to your left knee (when in the drivers seat) that's where the ECU would live... |
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 ![]() ![]() ![]() |
Thanks for the prompt replies guys, will take a look and see what I can find... |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
As per Stan's reply, the switch was not fitted to my 62 plate Westie either.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Does it illuminate green? Current stable:
Nope, the switch does not illuminate, not had a chance to pull any trim off yet, but suspect the good stuff has been taken out along with the steps themselves |
i'd be surprised if the wiring was taken out as its a difficult job to install it.... ... - .- -.
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 ![]() ![]() ![]() |
I used to be in the workshop for a large family owned haulage firm and when it was time to return the top bosses 2008 L322 at the end of the lease he bought it into the workshop and asked me to remove the deployable steps and mud flaps as he had to pay for those so he wasn’t letting the lease company have them, I set about removing the entire kit including the loom but decided to leave the switch as I didn’t have a blank to put back in its place and didn’t want to leave a hole. The saddest part the steps were still in the same place in an electric cupboard in the workshop when I left in 2014 which is irritating as they look quite smart on my L322 and they prob ended up in a skip |
