Petrol Guage problem after fuel pump replacement | |
Hi Guys
I had to have a new fuel pump fitted to the car last week, and the petrol gauge is now wrong!, i couldn't find anything in wiki so i looked through the RAVE manual and came across this piece of info (Below) the range counter on the central console screen (miles left in the tank) has also gone mental, the miles counting down way to fast for the actual distance overed, i hope that makes sense, I was really concerned that the engine management system, would want to shut the car down, when the mileage range hit zero! which might have been a bit of fun whilst on the motorway anyhow I watched closely as the miles counted down, 3.. 2.. 1.. 0.. then ---, no warning bong, no message displayed, she just carried on driving as normal (Phew)
Also when i picked her up i noticed the tickover was high, probably increased by 250-300 rpm, but still under 1000 rpm. i ignored it presuming it was high as she hadn't warmed up yet. the petrol level was low when i took her in, my plan was to put approx. 1/4 tank - £40 the next morning. anyway next morning, started her up, revs were high, and didn't drop when she had warmed up, so a phone call to garage was to be made later on. went to petrol station, chucked £40 no movement on petrol gauge.
just to confuse things even more, the tick over revs have now gone back to normal (in park) however there does seem to be a little flutter in increasing revs, and slight surge forward (increase in speed) when driving really slowly, speed limit here at the caravan site is 10 mph. i know what the rev count should be at a certain speed on the motorway, and that is still spot on.
so i suppose I'm looking for help / advice with two questions 1) any ideas on the rev issues? 2) does anyone know how to 'Reset' the fuel gauge? i of course have absolute confidence in the information i found in RAVE, and it makes perfect sense to me, that the problem with the gauge is a result of the processes described below
FUEL DELIVERY – V8
DESCRIPTION AND OPERATION 19-2-7
Fuel Pump
Should the fuel pump electrical connection need to be disconnected, it is imperative that the ignition should be switched off. If the ignition is on in any position the fuel gauge will memorise its last needle position prior to power down. Once power is restored the gauge will display the last remembered position regardless of the actual level of fuel in the tank. This will result in incorrect fuel gauge readings if the fuel tank has been drained and not filled worth exactly the same quantity of fuel that was removed.
as always, any help greatly appreciated
regards
steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
