Home > General > 3.6 vs 4.4 TDV8 MPG
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
3.6 vs 4.4 TDV8 MPG
Hi all.
I'm sure this topic has been covered many a time but I wondered if you could share your mpg figurers and thoughts for the 3.6 vs 4.4 TDV8 please.
Thanks in advance.
G
Post #518464 14th Jun 2019 2:26pm
it depends on how you drive..someone might get 30/32 from a 4.4 whilst someone else less..
dont worry about the mpg ,just buy and enjoy because in the great scheme of things you only live once..
Post #518466 14th Jun 2019 2:30pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
100% agree with Stan but i noticed an increase in mpg after changing to a 4.4 Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #518472 14th Jun 2019 3:28pm
8810bigcat
So far my 3.6 with mainly local journeys around 32ish, better on a motorway run and even around town 20%+ better than the Discovery 3 the RR has replaced.
Post #518473 14th Jun 2019 3:28pm
cass
I’m running both and the 4.4 is definitely a good 10% better than the 3.6 but the 4.4 tends to get used on longer journeys. I rarely take any notice of MPG as I believe it is completely irrelevant in terms of running costs, even if my 4.4 was doing 50mpg it would still cost more to run as it is still depreciating rapidly but my 3.6 has virtually stopped.
Post #518482 14th Jun 2019 3:57pm
DrRob
4.4 will do more but it’s all relative Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518486 14th Jun 2019 4:57pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Don’t let your relative drive it then Rolling with laughter David
Please let me know if my comments upset you, I may wish to upset you again.
Post #518493 14th Jun 2019 5:43pm
dolph34
Meant to say both my 3.6 and 4.4 were remapped 👍👍 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #518504 14th Jun 2019 7:11pm
having had both I can honestly say that I don't care...... Whistle
you put fuel in it
it moves forwards (most of the time)
you put more fuel in it when it runs low.
its a never ending cycle of driving joy. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #518511 14th Jun 2019 7:34pm
grey17
Thanks guys.
I'm still looking but needle could swing either way at this stage.
On the plus side for the 3.6, it sounds more like a V8!
G
Post #518514 14th Jun 2019 7:59pm
4.4 every time as it has the 8sp gearbox Thumbs Up
3.6's suffer with turbo failure and have the much poorer 6sp gearbox...
A no brainer if £££ are not permissive Thumbs Up
Post #518522 14th Jun 2019 9:29pm
DrRob
Craig is not wrong Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518524 14th Jun 2019 9:33pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I came to fatty ownership from a Touareg and have just had the pleasure of towing my 2 tonne caravan for the first time. It used less fuel than my Touareg 32 mog plus around town and an amazing 25.2 mpg towing. There’s something special about doing the legal limit with the 2 tonne van on its back at a leisurely 1200 rpm. I can’t speak for the 3.6, I was advised the 4.4 was superior in many ways and I feel this was good advice. If you go the 4.4 route make sure the turbo drain mod has been done or budget £1000 or so to get it done. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #518542 15th Jun 2019 8:03am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I guess you'll be put off by a SC then, whether 4.2 or 5.0 Rolling with laughter Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #518543 15th Jun 2019 8:36am
grey17
[quote="AJGalaxy2012"]I came to fatty ownership from a Touareg and have just had the pleasure of towing my 2 tonne caravan for the first time. It used less fuel than my Touare.......
Hi AJGalaxy2012
Thanks mate, thats a good shout regarding the turbo drain and I'mm assuming that that is the cause of the common oil leak on the 4.4?
1200 rpm is just about ticking over Smile
G
Post #518551 15th Jun 2019 10:15am
