Home > General > 3.6 vs 4.4 TDV8 MPG |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
All good points made above. I would just add that work out what kind of journeys you will usr it for.
15th Jun 2019 10:51am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
The turbo drain mod in my view is essential. Oil builds up in the second turbo that only spins up above 2500 rpm which in normal driving can be never! Teh first time you overtake someone or give the beans the scene behind will be something out of a James Bond movie. The smoke can be so dense as to be dangerous. The drain mod gives an independent line back to the sump for each turbo stopping the back pressure building up and oil leaking into the second turbo. Not all 4.4's do it mine definitely did, if you drive round continually like a boy racer no problem, do sedate driving for 10 or 15 miles and then open it up oh dear, not good.
15th Jun 2019 4:31pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
They don't all suffer with this issue though - Mine hasn't had the mod done and never has any problem with smoke. 2010 4.4 TDV8 Vogue SE |
20th Jun 2019 8:35am |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 200 |
Turbo Drain Mod you say? TM |
22nd Jun 2019 10:56pm |
[quote="grey17"]
Common Oil leak? |
22nd Jun 2019 10:57pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2523 |
The turbo drain mod and the oil leaks in the V are different items. The drain mod provides an extra drain direct to the sump to overcome oil build-up in the inlet tract if the turbo isn't exercised regularly and the oil leak is from the oil cooler gaskets and/or the O-ring at the back of the oil cooler. |
23rd Jun 2019 12:27am |
