![]() | Home > In Car Electronics (L322) > 2010 reverse camera view seems wrong? |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
WB
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Thanks rfjj and gonna_go_double_r,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Here's mine. I do have surround cameras and my yellow lines bend when I steer. But aside of the overlay graphics I have my rear glass visible in the bottom say 20% of my screen.
Thanks for the photo, I'm a bit surprised they all show so much of the rear glass as on the 2008 it didn't show any - I guess it's the sacrifice of having a wider angle camera and having it mounted on the spoiler.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Might be an idea for you to take the spoiler off and look at the connections before you try sourcing a replacement as there are more than one type of camera |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
Doesn’t actually matter what the focal length of the lens is, even if you changed it the viewing angle which misses the bumper will still be the same, only way to change it is tI physically move the camera somehow.
Thanks, I will do that. I've been through the part numbers there seem to be two types LR031815 (fixed camera - two connections on the harness) and LR031812 (cars with surround cameras and one connection on the harness). Annoyingly I have the fixed which also happens to be more expensive from LR hence my search for a used one. I've looked at some aftermarket ones but I'd really prefer to stick to LR parts. |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Just fit a good quality Sony camera for about £60. Its easy to do. Maybe a bit of soldering but not difficult.
tinribs Member Since: 23 Jun 2017 Location: UK Posts: 20 ![]() ![]() |
WB - did you ever get round to replacing the camera. Mine's done exactly the same (reversed the image and removed the guidelines). Just wondered where you purchased your replacement camera from?
Hi,
