Home > In Car Electronics (L322) > 2010 reverse camera view seems wrong?
WB
Have just bought a 2010MY L322 and the reverse camera view seems very odd in comparison to my previous 2008. Picture quality is much better however there is a large obscured area at the bottom and at the top right corner of the image.
Also the rear wiper seems to just clip the spoiler so I think somebody may have had the spoiler off and not refitted properly?
I’m not sure if it should have any overlay graphics or if that’s only on cars with surround cameras?
Any thoughts on alignment or other potential causes?
Also if anyone could please point me to or take a photo of what it should look like that would be much appreciated.
Many thanks
Post #518094 11th Jun 2019 8:29pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
My 2010 L322 has overlay graphics and it's not got the surround cameras..
Post #518096 11th Jun 2019 8:53pm
WB
Interesting thanks, I'll investigate further and post some pics tomorrow.
Post #518111 11th Jun 2019 10:11pm
WB
I've had a look this morning and gone into the diagnostics menu to check for any settings but can't seem to change anything.
Below is what my image looks like - it's super wide but also includes a large chunk of rear window at the bottom. I'd quite like to get it back to normal and would like the overlay graphics if they're supposed to be there.
I took a photo of the camera itself too which looks standard to me but I guess it's possible the previous owner had changed it for a wider angle one?
Any ideas wise folks of the forum?
Post #518128 12th Jun 2019 7:57am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
That does look a bit weird!
Maybe someone has fitted a 120 degree aftermarket?
Mine has static marker lines -- I understand the multi camera system has moving lines.
I do get a bit of (reflection?) as the bottom of your screen but only about half of what you see Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #518140 12th Jun 2019 9:03am
check the fit of the spoiler...
Post #518163 12th Jun 2019 10:47am
WB
Thanks all, I think it may be spoiler fit as the wiper is fouling but where are the graphics/lines I wonder?
Post #518180 12th Jun 2019 1:10pm
WB
Just took off the spoiler and refitted - wiper fouling is fixed but the camera image is much the same. The camera housing does seem to move a bit if I push on it so I suspect it’s either been repaired or replaced at some point. I think I’ll look out for a used camera on the bay from a breaker to try.
Post #518182 12th Jun 2019 1:47pm
you're halfway there Thumbs Up
Post #518186 12th Jun 2019 2:32pm
WB
Thanks Stan, will keep this thread updated with any progress.
Post #518193 12th Jun 2019 3:05pm
WB
The plot thickens... hadn’t noticed before the image is mirrored left to right which is less than helpful. Really need a replacement...
Post #518233 12th Jun 2019 7:31pm
theres a couple of how to's in the wiki that could help you..
Post #518242 12th Jun 2019 8:05pm
WB
Thanks Stan, will have a look at the wiki. Bit more googling I’ve discovered the flipped image and graphics disappearing is a known issue caused by a defective camera. The camera looks genuine so I suspect this is the issue mine has. Apparently there is an LR bulletin about it too which I’m trying to locate.
Thanks again
Post #518248 12th Jun 2019 8:22pm
GGDR
Image actually looks ok to me....
. Cheers, Greg
Post #518250 12th Jun 2019 8:44pm
WB
Thanks gonna_go_double_r - is yours similar?
Post #518254 12th Jun 2019 8:54pm
