Home > Maintenance & Mods (L322) > Swollen nuts |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Yep I can see the caps as you say. No real reason for stainless to be exorbitant price the raw material isnt massively different in cost and the CNC machining is the same so it can only be down to market forces. Ive turned up a few Prop Nuts for model aircraft out of hexagonal stainless bar, I may just devote some time to making a set of these.
8th Jun 2019 4:10pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3788 |
Is it only Wrington that do Stainless nuts? Geoff |
8th Jun 2019 6:51pm |
Any half decent machine shop with a CNC lathe should be able to belt them out no problem BMW i3 Electric Car
8th Jun 2019 6:57pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
The solid ones I bought are made from mild steel, but have been either Zinc plated or galvanised dipped, and they are fine.
8th Jun 2019 7:30pm |
Found it I think...
8th Jun 2019 7:45pm |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 |
Or this ones?
8th Jun 2019 9:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
JLR do solid ones too but only in black for now Circa £260 a set... |
8th Jun 2019 10:48pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 540 |
Are these the ones with the secret core of solid gold? Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
9th Jun 2019 7:19am |
Maybe there’s a car connected to them? |
9th Jun 2019 7:29am |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 208 |
I’ve just bitten the bullet and ordered a full set of black nickel wheel nuts from Wringtons. Got fed up with my basic bog standard wheel nuts going rusty but didn’t want to go down the chrome-capped route either. Wasn’t sure about spending that amount of money on the RR but convinced myself that it was an investment! 😉
9th Jun 2019 5:48pm |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
I dip my nuts in a dish of old engine oil for a few mins whenever they are off so it seeps under the stainless steel skin, wipe off the excess and refit and they are still nice n 22mm... 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
10th Jun 2019 4:48pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Always pays to check for swollen nuts 🥜
11th Jan 2020 3:18pm |
