![]() | Home > Maintenance & Mods (L322) > Swollen nuts |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Yep I can see the caps as you say. No real reason for stainless to be exorbitant price the raw material isnt massively different in cost and the CNC machining is the same so it can only be down to market forces. Ive turned up a few Prop Nuts for model aircraft out of hexagonal stainless bar, I may just devote some time to making a set of these.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3898 ![]() ![]() ![]() |
Is it only Wrington that do Stainless nuts? Geoff |
Any half decent machine shop with a CNC lathe should be able to belt them out no problem BMW i3 Electric Car
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3826 ![]() ![]() ![]() |
The solid ones I bought are made from mild steel, but have been either Zinc plated or galvanised dipped, and they are fine.
Found it I think...
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
Or this ones?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
JLR do solid ones too but only in black for now ![]() |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 546 ![]() ![]() ![]() |
Are these the ones with the secret core of solid gold? Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
Maybe there’s a car connected to them? |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
I’ve just bitten the bullet and ordered a full set of black nickel wheel nuts from Wringtons. Got fed up with my basic bog standard wheel nuts going rusty but didn’t want to go down the chrome-capped route either. Wasn’t sure about spending that amount of money on the RR but convinced myself that it was an investment! 😉
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
I dip my nuts in a dish of old engine oil |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4335 ![]() ![]() ![]() |
Always pays to check for swollen nuts 🥜
