Home > Technical (L322) > TDV8 inlet manifold change |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Or if anyone has access to the workshop manual could they possibly have a look at the instructions? |
23rd Nov 2018 6:15pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
This thread should give you all the info you need with pictures wtc. Looks easy enough just lots of bits to remove
23rd Nov 2018 6:36pm |
Link to the vm manualto assist
23rd Nov 2018 6:37pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
how spannery are you?
23rd Nov 2018 6:42pm |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 |
Mine has also gone on the drivers side, i have both sides ready to fit just not had the time and since i used sikaflex to temporarily repair the crack it still hasnt failed! When i get around to it i will take plenty of photos but with a baby due christmas day i cant see it being anytime soon! 2004 td6 l322 - gone
23rd Nov 2018 7:20pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
I recently assisted my son in changing a 3.0 TDV6 manifold. The 3.0 WSM states that the injector pipes, the rail balance pipe and the pipe from the HP pump to the rail are single use although we didn't replace the rail balance pipe or the pump pipe due to not being able to get access to the pump end connector or the other end of the balance pipe without lots of extra work. The injector pipes are more likely to leak if re-used because the injectors are unlikely to be refitted at exactly the same orientation but as the 3.6 injectors run at lower pressures than the 3.0 TDV6, re-used 3.6 injector pipes may not run the same risk of leaking. However the 3.0 injector pipe kits include new injector washers, O-rings and clamp plates which distort when tightened. |
23rd Nov 2018 8:05pm |
Thanks for all the replies. I'm going to download the workshop manual and have a look at that.
24th Nov 2018 4:47pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Where is it cracked? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
7th Jun 2019 6:30pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
I have just done the left hand side due to a leaking gasket, left side you have to lift the engine to get injector #8 out. Wasn’t a bad job at all, manual states fuel fails etc are all single use. You’ll need the injector puller’s but they come out ever so easy. All in all a easy job.. just time consuming, especially if like me you like to clean everything up.
7th Jun 2019 7:18pm |
Sorry yes. I thought that’s why you’d changed it because of a split. Common apparently. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
7th Jun 2019 7:37pm |
Nah mine was just leaking oil back up the injectors as the gasket had failed.
7th Jun 2019 7:44pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Is there a good "How to" for this job, I can find various bits but not a comprehensive write up? I will be doing the Left-hand side soon and looking for info. I don't want to be removing unnecessary parts and making the job harder. I am unsure if removing the solenoid from injector no 8 is a good idea.
14th Dec 2021 12:27am |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 65 |
Regarding injector 8......
28th Dec 2021 4:38am |
Thanks nick4275 for this and the reply to the other thread. I still have not done the job but it is imminent, I know have the gasket and also spare injector bleed off clips. My leak comes and goes so not desperate. I did find a decent how to on AULRO, here is the link if anyone gets here looking for pointers...
28th Dec 2021 8:29am |
