Home > Maintenance & Mods (L322) > Swollen nuts
Andy
Swollen nuts
Anyone else got swollen wheel nuts?
I’ve just taken my front wheel off and the wheel brace didn’t fit the nuts. I had to use a 23mm socket on them. On closer inspection, the stainless steel covers appear to be bulging slightly at the sides and just enough to stop the wheel brace fitting them properly.. The wheel brace fits the other nuts on the rest of the wheels so I can only assume the nut(s)might be rusty underneath the covers and has forced them outwards at the sides.
Is this normal ?
TIA 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517711 7th Jun 2019 6:21pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Swollen nuts is just another advantage of being a Full Fat owner.
I bought a full set of new ones so that I can replace them one at a time when they swell.
I should’ve been a Boy Scout...... 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #517713 7th Jun 2019 6:23pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Perfectly normal for the crappy OEM nuts.
Best binned along with the locking wheel nut and replaced before one splits and leaves you in the brown and sticky stuff. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #517714 7th Jun 2019 6:26pm
Andy
Not just mine then!
Where can I buy good quality replacements? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517719 7th Jun 2019 6:39pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
You can get more of the same type off ebay for about £40 a set where people have taken them off a new vehicke to eg change colour etc. Look for "New take offs". They are "As new".
Dan at Duckworthparts probably also has plenty as they've always got new take wheels & tyres where owners have specified a wheel / tyre change Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #517722 7th Jun 2019 6:51pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
+1
I opted for the easy (not cheap solution) with solid marine grade polished stainless ones from www.wrington.co.uk/
Part Number: WN1415LRASPTPOL
(double check this number on web page as will not fit older than 06 Range Rovers)
Post #517724 7th Jun 2019 6:57pm
DrRob
Swollen nuts is common across all models.
LR design feature Whistle Rolling Eyes Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #517744 7th Jun 2019 8:55pm
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
You need to see Dr F Very Happy
Post #517745 7th Jun 2019 9:22pm
mpirie
It's a common side effect of the main dealers having us by the short and curlies.
Mike
Post #517763 8th Jun 2019 8:54am
Baltic Blue
I solved it by buying a full set of 20 solid nuts that were on eBay at roughly the same price.
They are a sort of galvanised finish which soon dulled to a silver colour which looks fine on silver wheels.
Unfortunately I can’t find the advert now to add a link.
I just remember they were advertised as alloy wheel nuts, but are actually steel nuts for alloy wheels.
But four years later they are as good as new.
Post #517764 8th Jun 2019 9:03am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Stainless ones on ebay £30 per set
https://www.ebay.co.uk/itm/FOR-RANGE-ROVER...ctupt=true
AJG BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #517769 8th Jun 2019 10:11am
Those have stainless caps sir. Not stainless nuts...
Post #517785 8th Jun 2019 12:38pm
AJGalaxy2012
Not what the listing says "NEW FULL STAINLESS ALLOY WHEEL NUT "
Youre probably right but one never knows, chinese do turn out some cheap products. BMW i3 Electric Car
Post #517787 8th Jun 2019 12:48pm
Bradders
They look like an OEM knock off with the same problem of rusting under the caps. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #517788 8th Jun 2019 1:01pm
Look at the pics closely and they have stainless caps... Why would you produce a stainless nut and then put a stainless cap on?
I wouldn't waste my time or money sir... Stainless nuts cost significantly more than standard nuts... Thumbs Up
Post #517789 8th Jun 2019 1:01pm
