![]() | Home > Maintenance & Mods (L322) > Changing from 2 x 7 pin to one 13 pin Towbar Electrics |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
My 2011 Vogue came with a Wesfalia towbar with removable hook and two x 7 pin plugs. My caravan has a 13 pin plug, and although I could use an adapter, I would prefer to fit a 13 pin wiring loom, and these are available here:
kevshore Member Since: 21 Dec 2018 Location: ne lincs Posts: 11 ![]() ![]() ![]() |
That should work. Converted a couple of these for customers. PF Jones are spot on. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
2011 is plug and play I thought with no CCF changes needed. I might be wrong....
The 2011 has no trailer module, but when I checked with GAP, they told me to set these three. 2011 Vogue TDV8 4.4
Gap tell me that these are the same changes set by the LR official diagnostics. They don't know exactly what affect they have. 2011 Vogue TDV8 4.4
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Our 59 plate TDV8 had two 7 pins. I just fitted a 13 pin and rewired it. Altered the CCF in IID and it all works a treat. Just cost me £8 for the 13 pin plug. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I guess you didn't replace the whole wiring loom, just the plug. Good cheap job. the complete loom costs £80 2011 Vogue TDV8 4.4
No. I was going to fit that loom that you had, but I’d converted my previous TD6 and I still had the wiring diagram so did this instead. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
