Home > Technical (L322) > iiD tool vs SDD
Deicist
iiD tool vs SDD
So, I've been eyeing up the gap diagnostics IID BT tool and trying to compare it to the JLR SDD software. The software seems to be relatively cheap to pick up, and an interface cable isn't expensive, so what can the IID do that justifies its price tag? Is it purely that it's more convenient to use since it's a bluetooth / app driven thing, or can it do stuff that JLR's own software can't do?
Post #517315 3rd Jun 2019 11:25am
In a word, SUPPORT Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #517333 3rd Jun 2019 5:41pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
it does do more things too Alan (IID that is)
And more elegant in my view. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #517336 3rd Jun 2019 6:06pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
+1 for the Iid , as others have stated support , easy of use , capability. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #517337 3rd Jun 2019 6:13pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
IID fits in your pocket, easy to use, search on here.
SDD needs a PC and a pass thru interface ( pathfinder interface quite expensive depends on MY) and a yearly subscription. Oh, and needs the PC (Panasonic Toughbook range recommended) to be plugged in and a (recommended) battery charger/supply to be able to use SDD.
Post #517367 3rd Jun 2019 11:16pm
Andy
I've had IID for years but I'm surprised at some of the things it cant do. I emailed GAP a log of my MAP sensor fault and the reply i got back was it could be several things, one of which being check operation of the turbo. I asked Pat if i could do this in the tool and he said it wasn't possible. So its got to go in to a garage for diagnostics now. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517376 4th Jun 2019 8:44am
Mikey
The position of the actuators can be viewed...
Post #517438 4th Jun 2019 6:16pm
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
but when a dealer hooks up a Toughbook, all the wires look complicated and more technical than a phone, so can charge much more!!
Post #542614 1st Feb 2020 10:56am
GGDR
where can you buy this kit?
. Cheers, Greg
Post #542619 1st Feb 2020 11:13am
yelnats69
Can anyone tell me how far you can drill down on the suspension, what either one is best for suspension diagnosis.
I have a problem just can't figure
Post #542623 1st Feb 2020 11:43am
Poprivit
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
The iid has most if not all he suspension covered what are you trying to do?
Post #542716 2nd Feb 2020 12:21am
yelnats69
I have the dreaded suspension fault on my 2011 Vogue 4.4D
from start-up everything seems fine around 10 miles I get the warning.
all air bags seem OK, in standard or off road selected vehicle holds height overnight.
its my belief, that the compressor is overheating and shutting the system down with the warning "suspension fault"
I am thinking that one or more of the height sensors could be faulty, and falsely telling the compressor to pump and overheat.
When I do get the suspension warning the car can drive for miles in the "standard" setting and I don't notice any change in the ride or feel of the car.
I am looking for a ride height test, if they need programing a tool to do both.
any information about the ride height and galley pressure for comparison.
The compressor seems to work fine but is fairly quick to overheat when worked hard.
I would like to know how you identify the different models of compressor,
I have a icarsoft i930 scanner that will read the existing values, but I don't think it will allow adjustment.
also I have the 2011 Vogue model with digital dash, seems like there may be changes in parts how can I find the right part number numbers.
any help will be appreciated.
Post #542814 2nd Feb 2020 10:19pm
