![]() | Home > Technical (L322) > iiD tool vs SDD |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6767 ![]() ![]() ![]() |
In a word, SUPPORT |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
it does do more things too Alan (IID that is)
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 for the Iid , as others have stated support , easy of use , capability. 2015 4.4 AB
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
IID fits in your pocket, easy to use, search on here.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I've had IID for years but I'm surprised at some of the things it cant do. I emailed GAP a log of my MAP sensor fault and the reply i got back was it could be several things, one of which being check operation of the turbo. I asked Pat if i could do this in the tool and he said it wasn't possible. So its got to go in to a garage for diagnostics now. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
The position of the actuators can be viewed... |
yelnats69 Member Since: 21 Dec 2019 Location: Dymchurch Posts: 35 ![]() ![]() ![]() |
but when a dealer hooks up a Toughbook, all the wires look complicated and more technical than a phone, so can charge much more!! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
where can you buy this kit? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Can anyone tell me how far you can drill down on the suspension, what either one is best for suspension diagnosis.
Poprivit Member Since: 11 May 2014 Location: East Yorkshire Posts: 27 ![]() ![]() ![]() |
The iid has most if not all he suspension covered what are you trying to do? |
I have the dreaded suspension fault on my 2011 Vogue 4.4D
