Home > Maintenance & Mods (L322) > Rear Brakes
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Rear Brakes
While doing a pre -MOT check I discovered that the nearside rear assembly was seized in the off position with very little pad contact, while the offside one seemed to be binding.
Took the bus for a quick spin round the block and checked the disk temp with my laser temp tool. The offside one was twice as hot as the nearside one.
I ordered a pair of calipers and 2 carriers (came with new sliding pins) and shims from Dan at Duckworth. Before fitting I painted all the metalwork with one coat of Hammerite Smooth Red.
NB: Calipers are stamped TRW
The brake discs are almost new so didnt need replacing
The old pads still had a lot of material, but decided to replace them with OEM pads bought from a local Main Dealer.
Part Number: LR055454
Bled the rears again. It sailed through the MOT with no advisories. Result Thumbs Up
Post #517110 1st Jun 2019 10:07am
Thumbs Up .
Post #517113 1st Jun 2019 11:22am
Strider
Cheers Joe,
Got to paint the front ones next, I've got some "Brembo" Stickers to go on as well.
Has anyone covered the stickers with clear lacquer or just left them exposed ??.
Thanks
Post #517127 1st Jun 2019 12:53pm
I just left them when I put new stickers, but I guess lacquering will help (as long as it doesn't "melt" the sticker - might need to test first ?) .
Post #517132 1st Jun 2019 1:08pm
Strider
Post #517134 1st Jun 2019 1:14pm
