Home > Maintenance & Mods (L405) > Westfalia detachable tow bar for facelift model.
Kasperss
United Kingdom 2019 Range Rover Vogue SDV6 Carpathian Grey
Does anybody now if the Westfalia detachable tow bar fits facelift l405 model, i have spoken to my local towbar fitting garage and they said is not available for new model yet but westfalia website showoing fitting for L405 2012-onwords models.
Post #517108 1st Jun 2019 9:48am
rjff
You may get some info from P F Jones about this. They seem to be able to supply many towbar sets. Phone and ask, worth a try.
https://www.pfjones.co.uk/land-rover-range...owbar.html
or ring Westpahalia themselves
https://www.westfalia-automotive.com/uk/contact/ Cheers
Richard
Gap IIDBT
Post #517493 5th Jun 2019 9:55am
Nigelhirst
United Kingdom 2013 Range Rover Vogue SDV8 Luxor
I had one fitted 18 months ago when my deployable one failed. Peter Bowman in Bury did an excellent job 2 days before I set off on holiday.
The unit is absolutely great.
Nigel 2013 Vogue SDV8
2014 Defender 90
2009 Freelander 2
Post #519158 20th Jun 2019 8:05pm
Kasperss
Hi, do you have to remove bumper middle section to use towbar or you can cut out a hole inside.
Post #519804 26th Jun 2019 8:57pm
Nigelhirst
Mine had a deployable one, and the detachable one fits under the ‘flap’ in the centre section without modification. I believe there are different designs of flap though (and they are expensive -£35+++, and VERY fragile), so if you haven’t already got a tow bar, you might have to buy the towbar style flap.
Believe me, it is much better than the deployable one. My OEM one failed 3 days before my holiday....
If you want a photo, let me know
Cheers
2014 Defender 90
2009 Freelander 2
Post #519806 26th Jun 2019 9:42pm
Mr Tee
It’s a replacement panel, will fire a photo up tomorrow for you Thumbs Up
Post #519809 26th Jun 2019 10:05pm
The deployable looks like -
This is the only photo I have of the removeable one though apparently it can be used with the cover in place, so guess the hole underneath is big enough to access the electrics.....
Post #519821 27th Jun 2019 8:02am
Mr Tee
This is with the detachable with the replacement panel. Once fitted, no need to fanny about at all:
Post #519858 27th Jun 2019 1:35pm
Kasperss
where did you get your replacement panel from? Is this genuine land rover one?
Post #520273 1st Jul 2019 7:10pm
Plenty on eBay Thumbs Up
Post #520281 1st Jul 2019 8:21pm
Mr Tee
Got it from Dan , £30 ish Thumbs Up
Post #520283 1st Jul 2019 8:34pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
From recent experience but with a current shape Q7 I understand that the supply of Westfalia bars isn’t great at the minute due to them moving production facilities this was feedback from both the local Indespension depot and PF Jones.
Post #520399 2nd Jul 2019 6:46pm
pierre_l
Switzerland 2014 Range Rover Autobiography SDV8 Santorini Black
I am not sure I understand - is it the original one or a specific one for westfalia?
Post #644914 6th Oct 2022 1:20pm
