Home > In Car Electronics (L322) > in car entertainment
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
hi all, i have had problems with my music system for some time now. i only get sound from the front centre and drivers door speakers. sometimes i get whistling and popping sounds from these.on a previous post it was suggested the other speakers where blown. i have proved they aren't by connecting them individually through another stereo at the amplifier by unplugging the amp and pushing wires into the speaker feeds. i have also stripped the amp and can not see any sign of water ingress or damage.
now here's the strange part. i have just changed my front brakes including the wear sensor, after this i was unable to reset the warning lamp. i tried the ignition on/off 10 times trick with no luck. i have a cheap OBD2 plug in device which i use on my wife's MX5 but is never recognised by the L322. i tried this again on the rangey and as per normal "no fault codes found".
so i decided to select "reset fault codes".
all the speakers started working and the pad warning light went out, unfortunately after a couple of minutes the speakers reverted back to only two but the pad warning light has stayed off. tried the reset again but no speakers this time. any ideas anybody.
Post #517022 31st May 2019 10:03am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Rear left cubby, look for corrosion on connectors on all modules Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #517023 31st May 2019 10:09am
razzer
yeah already looked into that. its pretty clean in there. unplugged them all and no sign of water ingress or corrosion.
Post #517024 31st May 2019 10:20am
Bushy30
Mine was the same (ish) found all sorts when I took the lids off the modules ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #517044 31st May 2019 1:56pm
ammar
England 2005 Range Rover Vogue SE 4.4 V8 Alveston Red
Hi,
I have a problem with my Stereo on L322 2005. It is stuck at logo and light is flashing. I changed the cd changer sometime back when it was showing me no valid discs error. I tried to bypass Bluetooth module but it never worked for me. I am not sure what could be the issue? Any suggestions/solution would be highly appreciated. Thanks
Post #556932 8th Jun 2020 3:28pm
