hi all, i have had problems with my music system for some time now. i only get sound from the front centre and drivers door speakers. sometimes i get whistling and popping sounds from these.on a previous post it was suggested the other speakers where blown. i have proved they aren't by connecting them individually through another stereo at the amplifier by unplugging the amp and pushing wires into the speaker feeds. i have also stripped the amp and can not see any sign of water ingress or damage.
now here's the strange part. i have just changed my front brakes including the wear sensor, after this i was unable to reset the warning lamp. i tried the ignition on/off 10 times trick with no luck. i have a cheap OBD2 plug in device which i use on my wife's MX5 but is never recognised by the L322. i tried this again on the rangey and as per normal "no fault codes found".
so i decided to select "reset fault codes".
all the speakers started working and the pad warning light went out, unfortunately after a couple of minutes the speakers reverted back to only two but the pad warning light has stayed off. tried the reset again but no speakers this time. any ideas anybody.
