Home > Technical (L322) > Tow bar electrics
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
Tow bar electrics
Hi I have a 2003 l322 se, I have a detachable tow bar which I have used so obviously there is a plug fitted, my question is should any lights illuminate on the dash or a buzzer when I indicate or am I just being paranoid! Lol I seem to remember years ago a buzzer was fitted in the boot so you knew that the caravan indicators were working??
Post #516379 24th May 2019 12:15am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
I have a factory fitted towbar on mine. There is no additional lights or beepers to indicate the trailer/caravan indicators are working.
If they're not working, you get a warning message on the dash "Check Trailer Lights". 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #516408 24th May 2019 12:46pm
steve1
Many thanks, thought I was missing something!!
Post #516481 25th May 2019 10:48am
mat10
Hmmm, I thought by law that there had to be either a visual or audible indication for the driver to show that the trailer indicators were working? My Discovery 4 had a separate green trailer light on the dashboard which illuminated when indicating and the trailer was connected. I've not yet towed with my Range Rover but I would expect the same for that as well. Just looked in the handbook and it shows there is a green trailer symbol in the warning lights.
Post #516518 25th May 2019 8:57pm
SidewaysMatt
Not sure about the later ones, but the early >2006 cars don't have a warning light.
You just get the error message on the dash if one of the trailer lights isn't working. You also get a light on the suspension height knob to indicate the air suspension is locked out (you can't adjust the suspension height when a trailer is connected). 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #516850 29th May 2019 12:13pm
mat10
I expect then that the early models were supposed to have had an audible buzzer fitted when the electrics were installed
Post #516982 30th May 2019 8:10pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
The pre 2010 models double flash the indicators if the trailer indicator isn’t working this cover the need for an audial or visible telltale for the trailer indicators not working.
Post #516983 30th May 2019 8:15pm
mat10
Thanks, Didn't know that....... you learn something every day!!
Post #516993 30th May 2019 8:47pm
