![]() | Home > Technical (L322) > 2011 tdv8 is this normal |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4328 ![]() ![]() ![]() |
We need a "how to decoke your inlet system" step-by-step guide on here |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2600 ![]() ![]() |
The throttle will be closed further to ensure that the correct (low) flow through the MAF occurs. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
So responsiveness and performance would be affected would you say Graeme?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Greg,
Interesting Mike, I'm still trying to understand the root cause of soot / DPF fill.
Greg,
Yes you're right Mike. I'm reaching 17.5g or even 20g for every tank of fuel. i.e. I'm having to do a regeneration per tank. Some tanks I don't get out of town so I can't get a 'natural' region within my tank cycle.
I have tried putting additives in just after topping up, but found over a 4-5 month trial period they make no noticeable improvement , but I do always use supermarket standard diesel.
What's your actual tank range Mike, do you set your trip when you fill up?
Yes, every time.
500 miles is very good Mike. But I'm not sure the miles remaining is accurate at all.
