Home > Technical (L322) > 2011 tdv8 is this normal |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
We need a "how to decoke your inlet system" step-by-step guide on here Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
30th May 2019 6:13am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
The throttle will be closed further to ensure that the correct (low) flow through the MAF occurs. |
30th May 2019 7:25am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
So responsiveness and performance would be affected would you say Graeme?
30th May 2019 12:11pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Greg,
30th May 2019 12:28pm |
Interesting Mike, I'm still trying to understand the root cause of soot / DPF fill.
30th May 2019 12:42pm |
Greg,
30th May 2019 1:04pm |
Yes you're right Mike. I'm reaching 17.5g or even 20g for every tank of fuel. i.e. I'm having to do a regeneration per tank. Some tanks I don't get out of town so I can't get a 'natural' region within my tank cycle.
30th May 2019 1:13pm |
I have tried putting additives in just after topping up, but found over a 4-5 month trial period they make no noticeable improvement , but I do always use supermarket standard diesel.
30th May 2019 1:38pm |
What's your actual tank range Mike, do you set your trip when you fill up?
30th May 2019 1:51pm |
Yes, every time.
30th May 2019 2:00pm |
500 miles is very good Mike. But I'm not sure the miles remaining is accurate at all.
30th May 2019 8:33pm |
