Home > Technical (L322) > How many Water Pumps are too Many?
FFRRWannabe
United States 2011 Range Rover Autobiography Supercharged Stornoway Grey
So, I have reviewed the maintenance history of the new (to me) 2011 RR AB that I will be picking up in a week. The most curious thing about the maintenance history compiled from actual records from Indie mechanic and Carfax, is that there have been a total of FIVE Shocked Shocked Shocked water pumps put on this vehicle not counting original over the course of 9 years and 122K miles!
Is there a known issue with water pumps or do you suppose that there was a few misdiagnoses of leaks?
First @ 24K miles
Second @ 45K miles
Third @ 87K miles
Fourth @ 104K miles
Fifth @ 119K miles (under warranty and at time of timing chain guides replacement)
Post #516880 29th May 2019 5:44pm
FFRRWannabe
Anyone... is there some unknown issue that plagues the 5.0 water pumps? Could it be a misaligned belt that is putting force on the bearing and wearing out prematurely?
Thoughts? 2011 Range Rover Autobiography
Stornoway Grey
Storm/Jet Seats
Center Console Storm
IP/Topper Jet
Grand Black Lacquer Finisher
Post #518274 13th Jun 2019 3:46am
dingg1
That was my thoughts , pulley off a wee bit , I'm onto 95000 and still on original pump afaik (4.2 though)
Post #518283 13th Jun 2019 7:47am
Dolphinboy
Make sure it is an OEM or hella brand. I replaced mine on a previous petrol engine FFRR and it went only a year later (bearings!)
Post #518366 13th Jun 2019 6:01pm
FFRRWannabe
They were all JLR. 2 while under LR care, the others under the independent LR shop. All repairs indicated the factory part. There is no sign of an issue, but there must be. At this point all I can do is hope that when the front end was apart to replace the timing chain guides that the reassembly solved the issue. Only time will tell. 2011 Range Rover Autobiography
Stornoway Grey
Storm/Jet Seats
IP/Topper Jet
Post #518413 14th Jun 2019 4:46am
Dolphinboy
Seems like the belt off line could be the cause then! It carries a lot of pressure on the front spindle.
Post #518425 14th Jun 2019 7:19am
