Home > Technical (L322) > Aux Coolant pump & Control valves
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Has anyone changed these & what the process like?. Hopefully someone with greater knowledge will advise accordingly. Bow down
I've had a quick look & removed the heat shield to one side. It appears that the bracket holding the valves & pump is held on by two M8 nuts.
If I remove these will the assembly pull up & give enough room to clamp the hoses & release the jubilee clips.
Petrol V8 2006 MY. Very Happy
Post #515822 19th May 2019 1:02pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
a photo would be nice as i am not familiar with what you are talking about RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #515826 19th May 2019 1:21pm
Highroller
Manged to find one on line. It sits on the LHD side of the engine bay.
Looks like there's another nut holding the bracket on below the assembly.
Post #515834 19th May 2019 3:04pm
knares
WOW
i have the same vehicle but i haven’t noticed anything like that on it
i will have to have a look RR 2005 4.4 petrol
Post #515839 19th May 2019 3:24pm
Gsxr1250dave
I replaced mine recently due to max heat drivers side its a bit fiddly but an easy swop out. Just remove the control valves you lose a bit of coolant no biggy just refill with a bottle down the hose you removed from the valve then fit the new one.
Post #515870 19th May 2019 7:36pm
Highroller
Gsxr1250Dave, Did you manage to remove the valves without the bracket. I was intending to clamp the hose to minimize the coolant.
I also have a pump to replace along with the valve setup. Many thanks.
Post #515875 19th May 2019 8:17pm
Gsxr1250dave
The mounting bracket for the control valves just lift out i also replaced the pump shortly after its only x1 bolt dont bother trying to get clamps in there just lift it all up the hoses are long enuf and flex ok coolant loss is minimal and like i said poor coolant down the hose just before you reconnect it
Post #515879 19th May 2019 8:32pm
Highroller
I'll give it a go Thumbs Up
Post #515882 19th May 2019 8:42pm
Highroller
As I've never had really good heating, I thought I would investigate. Changed the control valves & auxiliary pump, but no great improvement.
Air con works fine on auto & manually when increasing the fan speed. However although the heater does blow out hot air, it's not really hot even though it's set at 28 degrees & appears to be the same as it was before.
Bled the system again, temperature reaches Normal & stays there all day.
Heater matrix pipes are hot & cleaned the temperature auto fan, as it had some dust on it.
Blend flap & all other flaps appear to be working, takes a while to change direction but it will change (passengers foot well not really blowing out that well compared to the drivers side).
Manually turning the fan speed I can obtain full speed (all lights LED lit up). Doesn't sound as high as when it's on Max though.
On Auto With A/C on the temperature is warm & fan speed drops.
Really running out of ideas here, was thinking about changing the FSR, but fan works ok, could look at the steeper motors, but again appear to be working. Am I missing something obvious here? Shocked
Anyone had similar issues. Bow down
Post #516870 29th May 2019 4:30pm
Gsxr1250dave
Have you adjusted the little wheel in the centre air vent ???
Post #516872 29th May 2019 4:44pm
Gsxr1250dave
Mine is toasty both sides and i mean toasty then when i need it to be its ice cold. My pump was duff and it was still hot did you fit a new pump or 2nd hand because the 1st pump i tried was 2nd hand and didnt work so fitted a new one and all dorted
Post #516873 29th May 2019 4:49pm
Highroller
Yep, I've even had the vent surround out to make sure that the bowden cable was still in one piece.
Found a wire that wasn't connected to anything when I took out the plenum housing, but it's the feed for a FBH change over valve, that I don't have. Censored
Post #516874 29th May 2019 4:49pm
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Do you have park heater? I found the seals in my changeover valve had swollen to the point that both paths were blocked. 2006 Supercharged
Post #516878 29th May 2019 5:33pm
Highroller
Gsxr1250dave, This is the issue, it's all new?.
Ian928, No park heater , therefore no change over valve.
Thanks for your thoughts though guys Thumbs Up
Post #516881 29th May 2019 5:52pm
Gsxr1250dave
You be able to feel the pump running i would start there maybe try flushing the heater matrix out its easy to get to if you remove the phlenum chamber fron the back of the engine
Post #516888 29th May 2019 7:53pm
