![]() | Home > Technical (L322) > 2011 tdv8 is this normal |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
You'd be shocked at the muck behind the butterfly if you consider that to be bad. It's caused by crankcase oil vapours mixing with EGR soot |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
Yes did notice the crap behind the butterfly, so from the jist of your answer this is a normal thing to happen? |
Unfortunately yes it's normal unless EGR is mapped-out. |
EGR not mapped, im waiting for parts to arrive which will be on Tuesday with luck .so gives me a few days to strip it off and give it a good clean.
Clean up done can’t believe how much crap I got out the inlet manifold is half it’s weight 😁
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
Jeez, what is that thing in the last two pics with the carbon deposits, and how do you get to it? 2011 Vogue TDV8 4.4
It's the pipe that connects the EGR valve to the inlet manifold and it's located at the top of the engine you can't miss it when you take the engine cover off |
If you look at the first picture in this post you can see the end of it just behind the throttle body butterfly |
Popeye Member Since: 15 Sep 2017 Location: Kent Posts: 27 ![]() ![]() ![]() |
Sounds like an easy enough job.
Haven’t got to driving it yet as I’m doing a top to bottom and front to back service on it,
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
I didn’t know the egr pipes had holes in them, mine and all the photos look like they are solid tubes. Didn’t bother cleaning mine, just stuck them in a bag on the shelf in the garage just for prosperity 👍 |
With out a hole in it how would the egr gas get into the air intake 🤔 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
With this so gummed up, what would the effect be?
I didn't notice any difference only reason I noticed it was because I had to take off the air intake pipe to change the front belt tensioner.
