![]() | Home > Maintenance & Mods (L405) > Another layer of security |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Ingenious! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
You could run a few Volts through the pins of the dummy socket as a little gift for the device that's lucky enough to end up in your car unannounced....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
good idea.. |
kevshore Member Since: 21 Dec 2018 Location: ne lincs Posts: 11 ![]() ![]() ![]() |
I had considered that. But one day someone legit will accidentally plug into it..... |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1435 ![]() ![]() ![]() |
Ingenious until you told the world!! |
Lets not help each other then, in fear of the chance of a thief finding this post and finding the one in a million car, with it fitted.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
I like that a lot |
Quote easy to add a covert kill switch too, perhaps on the transmission controller.
life was much simpler then greg , good times |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1245 ![]() ![]() |
Ditto Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
In the 70s I used to take the rotor arm out if somewhere iffy. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
In the 70’s I used to carry a rotor arm and HT lead in my pocket just in case I needed to get home in a ‘abandoned’ car 😗 |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Many years ago when I worked in Paris and had to leave my car in a station car park in the suburbs, I fitted my own secret cut-out switch. I took out the bits at the end of the car cigarette lighter and fitted a simple on/off push-button switch right at the end so that you could actuate it with a finger pushed into the cigarette lighter socket. The coil LT lead was connected across the switch.
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 136 ![]() ![]() ![]() |
I used to have a kill switch fitted to both my old cortina's...but then I did used to live in some very dodgy areas |
