Home > Maintenance & Mods (L405) > Another layer of security
kevshore
United Kingdom 2013 Range Rover Vogue SE SDV8 Nara Bronze
As a mechanic, it has always bugged me that considering car thieves often use the OBD socket to steal a car, that manufacturers put it in such an accessible place.
I have this afternoon, moved mine into the upper glove box and it can now be locked with the 'valet' function, when leaving the car.
Simple job. Buy an OBD extension cable and route behind the dash.
Just to confuse them more, add a dummy OBD socket in the originals place, wiring up the ground and battery feed. It looks like its connected then, but no communication. Laughing
Image isn't very good, but you get the idea....
Post #516503 25th May 2019 6:06pm
ur20v
A Trap
Ingenious!
Post #516506 25th May 2019 7:14pm
GGDR
You could run a few Volts through the pins of the dummy socket as a little gift for the device that's lucky enough to end up in your car unannounced....
. Cheers, Greg
Post #516509 25th May 2019 7:59pm
good idea.. Thumbs Up
Post #516511 25th May 2019 8:12pm
kevshore
I had considered that. But one day someone legit will accidentally plug into it.....
Post #516512 25th May 2019 8:13pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Ingenious until you told the world!!
Post #516514 25th May 2019 8:24pm
kevshore
Lets not help each other then, in fear of the chance of a thief finding this post and finding the one in a million car, with it fitted.
Wink Laughing
Post #516517 25th May 2019 8:53pm
I like that a lot Cool
Post #516521 26th May 2019 5:17am
GGDR
Quote easy to add a covert kill switch too, perhaps on the transmission controller.
In the 70;s my Dad would whip the HT lead off the coil if he ever left the car somewhere iffy.
. Cheers, Greg
Post #516523 26th May 2019 7:22am
life was much simpler then greg , good times Wink
Post #516524 26th May 2019 7:29am
Bill
ur20v wrote:
Ingenious!
Ditto Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #516545 26th May 2019 11:06am
Weegie
In the 70s I used to take the rotor arm out if somewhere iffy. Cool John
GAP iiD BT
Post #516549 26th May 2019 11:46am
ur20v
A Trap
In the 70’s I used to carry a rotor arm and HT lead in my pocket just in case I needed to get home in a ‘abandoned’ car 😗
Post #516553 26th May 2019 12:30pm
bebechoon
France
Many years ago when I worked in Paris and had to leave my car in a station car park in the suburbs, I fitted my own secret cut-out switch. I took out the bits at the end of the car cigarette lighter and fitted a simple on/off push-button switch right at the end so that you could actuate it with a finger pushed into the cigarette lighter socket. The coil LT lead was connected across the switch.
With the cigarette lighter bit itself replaced, no one would know …
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #516560 26th May 2019 2:35pm
Crasher242
I used to have a kill switch fitted to both my old cortina's...but then I did used to live in some very dodgy areas Smile Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #516938 30th May 2019 11:40am
