Home > Camping, Caravanning and Holidays > Does anyone tow a caravan with the farmers hitch?
Andy
If so, what holes are you fixing the tow ball to?
I had mine on the top set and it freaked badly all the way to Wales and back. When I got to site I removed the hitch pads and they were glazed over. I cleaned them with some sandpaper but it still creaked on the way home.
When I offered it up against the detachable one, it was too high. I’ve since bolted the tow ball onto the middle set of holes and it’s now the same height as the detachable one.
I’m not sure whether this will stop the creaking noise. Will find out this Friday when we tow again. [/u] 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #515874 19th May 2019 8:09pm
Does the caravan have a recommended ball height ?
I used to use the lowest ones with my Ifor Williams
Post #515876 19th May 2019 8:18pm
Andy
I don’t know to be honest. I’ll look into that 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #515880 19th May 2019 8:37pm
Balloonengineer
Middle set of holes.
However I actually cut off the bottom set of holes to give more ground clearance, so arguably its now the bottom set of holes!!!
More importantly looks much better too.
What do you think of my alternative for trailer towing. I have been using a tow bar carrying rack for decades.
The RR 2 inch box hitch makes it easy to fabricate, and fit and remove. This one is aluminium and folds up into nothing.
Does get the odd look down a motorway, but is legal.
Best wishes
Glen
 Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #515997 20th May 2019 8:28pm
A bit like the Thule Easybase Thumbs Up
Post #516002 20th May 2019 8:46pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Spray the tow ball and caravan hitch with break cleaner, that’ll stop the noise Thumbs Up 2014 vogue se
Post #516035 21st May 2019 4:41am
Andy
I did. Still creaked like a haunted house door on the way back. Fine in a straight line but as soon as I turn left or right there it is. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #516041 21st May 2019 6:55am
TJH1985
Middle here.
Our issue was with the small amount of play between the two, causes a 'knock' which was solved with a Anti-Rattle Stabiliser Thumbs Up
Post #516139 22nd May 2019 7:39am
Andy
Anti rattle stabiliser? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517728 7th Jun 2019 7:17pm
TJH1985
One of these:
https://www.amazon.co.uk/Tightener-Anti-Ra...B074DCG2PQ
Post #517730 7th Jun 2019 7:21pm
ur20v
A Trap
Balloonengineer, that is one mahoosive picnic blanket... sure must impress the wife/girlfriend/mistress when you set up for lunch on a stately home lawn
Post #517753 8th Jun 2019 6:43am
stu
I used to use the farmers hitch to tow my plastic palace, I used the middle set of holes, there is a legislation for tow bar and trailer heights.
Hope this helps.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #522410 21st Jul 2019 5:20pm
