![]() | Home > Camping, Caravanning and Holidays > Does anyone tow a caravan with the farmers hitch? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
If so, what holes are you fixing the tow ball to?
I don’t know to be honest. I’ll look into that 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 ![]() ![]() ![]() |
Middle set of holes.
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5 TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made, Now 3x FFRR, some would say I should have learned by now...... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7993 ![]() ![]() ![]() |
A bit like the Thule Easybase |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 753 ![]() ![]() ![]() |
Spray the tow ball and caravan hitch with break cleaner, that’ll stop the noise |
I did. Still creaked like a haunted house door on the way back. Fine in a straight line but as soon as I turn left or right there it is. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Middle here.
Anti rattle stabiliser? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
One of these:
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Balloonengineer, that is one mahoosive picnic blanket... sure must impress the wife/girlfriend/mistress when you set up for lunch on a stately home lawn |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
I used to use the farmers hitch to tow my plastic palace, I used the middle set of holes, there is a legislation for tow bar and trailer heights.
Hope this helps.. ![]() Past: TDV8(4.4) Vogue Discovery 3 Commercial TDV8(3.6) Vogue TD6 Vogue D2 V8 ES D1 V8 ES RR Vogue Classic |
