Home > In Car Electronics (L405) > Wifi Hotspot
Chalky
Wifi Hotspot
With a simcard plugged into the car should a Wifi icon show in the lefthand top corner of the infotainment screen or just 3 or 4G? All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #515705 18th May 2019 10:38am
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
IIRC the WiFi icon only shows when the vehicle has connected to an external WiFi network.
Post #515716 18th May 2019 12:00pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Don’t have ICTpro in the Fatty, but did in the previous F Pace. So far as I recall, if the SIM was in and valid the wifi icon displayed top left.
Post #515728 18th May 2019 3:50pm
Chalky
Only 3 or 4G on mine. How does one know when the simcard is invalid? All LR cars from 1984
Post #515739 18th May 2019 6:15pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Mine would show 3G in the top right corner of the information once the SIM was active about 10 seconds after start up, Ive since removed the SIM as 3G is crap, and now its got a sort of wifi signal logo crossed through in red colour, so I know its not functional.
65 plate car
Post #515857 19th May 2019 6:18pm
Chalky
Thanks for your replies.
Car going to dealers on Wednesday to see if software can be sorted. Satnav and ACP are still having problems. All LR cars from 1984
Post #515932 20th May 2019 11:01am
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
My sim just ran out on my 17MY after owning the car for 11 months. It was a 12GB sim from 3. I found the first thing that I noticed was the Map view which is normally in satellite mode wouldn't load but it still showed 3G on the ICP screen. When I tried to load a web page it wouldn't have it so swapped the card for another 3 sim and hey presto it all worked again. So after I'd done this the system told me I was about to run out as I had reached 12GB. I would say this was about two days after it actually ran out. You do have to set the system to understand what size of GB was on the sim to begin with. Best to do this as you insert the new card as I have done. My new card is a 24 month/24GB jobbie so don't expect to run out for a while yet.
Post #515962 20th May 2019 4:04pm
Chalky
Thanks for the reply. Seems I still have some data left as 4G showed on screen this morning. All LR cars from 1984
Post #515964 20th May 2019 4:24pm
Huwrhys
Hi Chalky
Mine showed 3G but wouldn’t load the LR version of Google maps. Just went blurred. It wouldn’t load a web page either. Maybe the 3G icon is to do with my settings so assumed as it was to run out a couple of days later. I set it at 12g a couple of days after I put the sim in if that makes sense.
Post #515967 20th May 2019 4:37pm
Chalky
Where did you set it at 12g, Huw? All LR cars from 1984
Post #515969 20th May 2019 5:03pm
Huwrhys
Pretty sure it was under all settings-connectivity-mobile data and then you can set the amount of data you have on your sim and details of the provider etc.
Post #515973 20th May 2019 5:25pm
Chalky
Thanks Huw, under the settings/connectivity/ mobile data do you have Roaming on or off? All LR cars from 1984
Post #515993 20th May 2019 8:17pm
Huwrhys
I have mine set to on as the current deal is Europe wide. If that changes I’ll turn it off if abroad.
Post #515995 20th May 2019 8:20pm
Chalky
So here in UK to on? All LR cars from 1984
Post #515999 20th May 2019 8:40pm
Huwrhys
On everywhere and off if the free roaming stops on the continent (if you’re there)
Post #516004 20th May 2019 8:50pm
