Home > Technical (L322) > Alternator help |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Kbald
18th May 2019 9:36am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Thanks will have a search around and see what I can find on here. Could be near new battery time after 4 years on this one too but it's been well maintained and refreshed using my ctek but nothing lasts forever. Current 2007 TDV8 Vogue Buckingham Blue |
18th May 2019 6:33pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
2007 seems to have been a bad year for alternators - so if you're still on the original, you've done well
18th May 2019 6:39pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 490 |
14.2volts you should see. Cheers
19th May 2019 5:19am |
Thanks. From memory it's been replaced before under warranty so isn't the original. Will try clean up the terminals on the battery and see if this helps. I'm getting no other symptoms of a failing alternator but from ready the other post they just seem to go without warning. Current 2007 TDV8 Vogue Buckingham Blue |
19th May 2019 8:01am |
Thinking on the battery, it could be part of the problem. When my alternator went the battery failed few months later. It was under 18 months old and was replaced under the battery warranty. Can't seem to find the voltages I took at the time.
19th May 2019 9:00am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
My volts are around 13.5v and maintains the battery at ~12.5v so don’t go rushing to replace things.
19th May 2019 1:16pm |
Thanks will keep an eye on it before getting my hands dirty.
19th May 2019 2:10pm |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 |
Hi there
24th May 2019 10:04am |
Thanks Pepi will give YouTube a look and see what the voltage is with everything on too. Current 2007 TDV8 Vogue Buckingham Blue |
24th May 2019 2:18pm |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 |
The electrics on these show some weird reactions to voltage fluctuations. I recently noticed that when I started the car in the mornings I briefly got a message hdc inoperable. Been like that for weeks but no issues driving or starting. Around the same time the radio started playing up couldn’t get a signal on radio 2 and several other stations where intermittent reception.
28th May 2019 11:15pm |
