Home > Maintenance & Mods (L405) > Seat Arm Rest Fix Anyone?
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all, the drivers seat arm rest has lost its tension so will just fall rather then lower slowly when lifted to put my seat belt into the buckle and height adjustment is very limited so assume the previous owner used to push down on it and has either bent or broker something inside?
Anyone have this happen, what did you do to fix, how does it remove from the side of the seat?
Thanks
Carl
Post #515639 17th May 2019 6:04pm
Tension ?
Mine just has a dial on the front end that you turn to set the position it stops at when you lower it......
Post #515644 17th May 2019 6:52pm
carlos50
Sorry, what Im trying to describe is the mechanical motion you can feel if you had the rest upright out of the way then pull it down to use as an arm rest, its gone floppy and just drops down.
The turning adjustment for the height doesn’t adjust it very well, think the bar down the rest has broken or something?
Post #515646 17th May 2019 6:56pm
I'll have to test mine - I never really move it - but I guess if it's different to the passenger side then there's a problem
Post #515647 17th May 2019 7:00pm
carlos50
Passenger side has a nice light pressure feel to gently lower it down but doesnt continue to fall if you take your hand off it, mine just flops to the low point thats its set to, no or very little resistance
Post #515648 17th May 2019 7:02pm
If you can't fix it, then these may be worth a punt to butcher.....
Post #515649 17th May 2019 7:08pm
Weegie
This might help as to how to access it.
https://www.fullfatrr.com/forum/topic20270...t=arm+rest John
GAP iiD BT
Post #515650 17th May 2019 7:21pm
carlos50
I was looking at those seats earlier strangely enough, will look around the rest over the weekend see if it becomes clear how to remove it?
Post #515651 17th May 2019 7:26pm
Laughing Those seats have to be close to worthless once you realise the airbags deployed.....
It does look like a proper faff to change though if you need to take the whole seat out, which you probably do Big Cry
Post #515661 17th May 2019 8:02pm
carlos50
Yeah possibly too much work just to change an arm rest
Post #515663 17th May 2019 8:27pm
Hopefully this might help sir... Thumbs Up
Post #515671 17th May 2019 10:19pm
Baltic Blue
This is L322 info on armrests, but it might be similar to L405?
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #515683 18th May 2019 7:46am
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Happened on our discovery. Just tighten the bolt up that holds it on the seat.
Post #515708 18th May 2019 11:23am
carlos50
The T27 was rock solid so think the mechanism inside must be broken and its made the arm rest a bit floppy, will live with it for now
Thanks everyone Thumbs Up
Post #516571 26th May 2019 3:42pm
Carlos, if you have the necessaries? Remove the securing screw and the armrest simply pulls off... If you look at this video
It should give you an idea how the mechanisms work inside Thumbs Up
Post #516683 27th May 2019 4:19pm
