Home > Maintenance & Mods (L322) > Out of action. Coolant low. Help with part number
mjdronfield
So, coolant low warning popped up just now.
It’s all over the front.
I can see this pipe off, guessing the plastic join has broke.
Do we know the part number please?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #515526 16th May 2019 4:06pm
Baltic Blue
http://www.fullfatrr.com/forum/topic48509.html
Easy fix Thumbs Up
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #515527 16th May 2019 4:08pm
mjdronfield
Many thanks.
I thought I’d seen something somewhere.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #515529 16th May 2019 4:18pm
mjdronfield
Do you need any special tools to undo the black hose clips?
The ones that aren’t jubilee clips?
Hoping I don’t need to buy too much antifreeze.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #515618 17th May 2019 2:43pm
Baltic Blue
I struggled a bit and finished up cutting it off and replacing it with a small jubilee clip. 8 - 12 mm.
Post #515620 17th May 2019 2:50pm
mjdronfield
That’s what I’m worried about. Not sure I have any.
Might have to go Halfords.....
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #515622 17th May 2019 3:09pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
A decent pair of pliers or a pair of nail pulling pliers work well on those black sprung clips
Post #515623 17th May 2019 4:07pm
mjdronfield
Magic, thanks. I have some of those..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #515624 17th May 2019 4:14pm
Jamiehol
The correct tool for them is a set of these https://rover.ebay.com/rover/0/0/0?mpre=ht...3052882376
but the small ones normal or nail pliers work, and the larger ones can be done with water pump pliers
Post #515629 17th May 2019 4:40pm
nino_nino
I adapted a pair of old pliers, it works OK.
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #515690 18th May 2019 8:54am
mjdronfield
Many thanks everyone, all fixed.
I’d already ordered the hoses from the dealer, at £80, as I needed the car on the road. Didn’t have any brake pipe or other bits to fix what was broken.
I called at Halfords and got 5 litres of concentrated OAT antifreeze but didn’t need that much in the end. I wanted to buy a tool for the clips but they don’t sell them. They hardly have any tools compared to what they used to do.
Fought the clips with some big pliers, but got there in the end. I kept all my existing hoses, bar the one which had come off. Thought it might have got harder or brittle over time, so put extra stress on the joint. Didn’t seem much different to the new one in the end, but as the other end just clipped in place, was faster than using old hose.
I’ve bled it all an it seems ok.
I did notice that on the new one there was no clip on the joint that broke. Might put a jubilee clip on, like in the pic above....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #515718 18th May 2019 12:39pm
mjdronfield
So why would Land Rover have clips on all the other hoses but the one that broke?
Looked at pics of engines on the web, and none of them have a clip on that specific hose.
I’ve put a jubilee clip on it now, but have I made a mistake to do so? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #515740 18th May 2019 6:21pm
mjdronfield
The belts are squeaking.....not entirely surprised..... what’s the easiest way of getting near them to do something about it? Any ideas? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #516125 21st May 2019 8:56pm
