Home > Maintenance & Mods (L322) > How much rust is acceptable?
Danwilderspin
I’m looking for an upgrade to a 4.2 and they all seem to be rust buckets at the back end/sills. I’m not going to name but is this acceptable for a 100k car 2007 for 8k? Or is it priced high with this level of rust? Those sill felt very thin
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #515329 14th May 2019 6:43pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Walk away. There must be better SCs than that!
Our similar age, higher mileage TDV8 is much better than that & there's no reason an SC can't be. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #515330 14th May 2019 6:51pm
Wouldn't touch it with a barge pole. It will be impossible to eradicate fully and whatever is done as a repair to the Cills will come back to haunt you after a couple of winters.
The suspension members are heavy lumps of metal and aren't too bad, a good wire brush and a coat of grease would keep them going for years. Thumbs Up
Post #515332 14th May 2019 6:57pm
ur20v
A Trap
Looks superficial and normal for UK, salt Kaiden roads there.. my Spanish FF has never been off road or seen salt so is like new underneath 😎
Post #515334 14th May 2019 7:05pm
Danwilderspin
I see you have an 04 are your sills in a better state?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #515360 14th May 2019 10:37pm
Had the car for 8 years but regularly treat it to a coating of oil and grease so to date no corrosion to cills or rear arches or for that matter anywhere else. Thumbs Up
Post #515377 15th May 2019 8:57am
CS
My 2004 was waxoyled when bought new and its underside was pretty good when it was sold in 2013. My 2012 by contrast needed a new upper tailgate and had wheel arch rust after 2 1/2 years. It had not been waxoyled as it was a used demo when I got it so not the same opportunity. But in general the later cars seem worse for corrosion, perhaps due to a combination of different paint regulations, higher scrap content in the steel and maybe some cost saving at JLR under Ford. The need to repaint the 2012 322's arches every year from year 3 onwards was a major contributor to my move to a 405.
It is disappointing that JLR did not do better, as the OP says particularly at the price. They protected the P38 much better, with vulnerable panels being galvanised, coated with anti-chip paint and then painted, so it's not as if they did not know what to do. The 322s were just painted, perhaps because so much of the production goes to salt-free countries and the cost of protecting UK etc cars was not thought worth it. Only Range Rovers since 1988
Post #515409 15th May 2019 12:41pm
Danwilderspin
so CS, do the 405 not suffer rust the same then?
What year does it start to go wrong will a 2005 4.2 be better from a rust free perspective than say an 08?
cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #515417 15th May 2019 2:06pm
CS
The 405 ought to be better given the aluminium architecture, the wheel arches and tailgate will be aluminium rather than steel. AFAIK the big issue with 322s is the structural nature of the hindquarters, making them costly to replace, and quite a big job too. "Lesser" components such as the tailgate are a costly nuisance too of course but not perhaps as fatal. There will be some steel components underneath the 405, it's too early for me to have a view on durability compared with the 322.
Sorry I can't help on the different years of 322, having had only 2004 and 2012, maybe some site sponsors who see lots of them can say. Only Range Rovers since 1988
Post #515420 15th May 2019 2:44pm
Sandyt
Have to say mine is on 180k and 10yrs and nowhere near as bad as that the cills are relatively rust free
Post #515441 15th May 2019 5:17pm
Danwilderspin
Wow that’s some big miles on an s/c - good to know they do exist if I keep looking Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #515442 15th May 2019 5:44pm
Sandyt
Had this one for coming up to 5 yrs and put over 120 on it they wear out so bits have to be replaced that's all
Post #515443 15th May 2019 6:18pm
Danwilderspin
You had any engine/sc/gearbox issues? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #515444 15th May 2019 6:22pm
Sandyt
Had a new gearbox on 100k due to a sticking solenoid why they replaced the whole gearbox god knows since then not a problem change gearbox oil every 30k and engine at 10k and diffs every year all good
Post #515445 15th May 2019 6:28pm
Danwilderspin
Good to know! Cheers! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #515446 15th May 2019 6:32pm
