![]() | Home > In Car Electronics (L322) > Harmon Kardon Logic 7HD |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I did.....then turned it back off. 2011 Range Rover Vogue SE 4.4 TDV8
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 ![]() ![]() ![]() |
My 2012 Westminster has exactly the same fault with the SW and Bass, it has been in the dealers on numerous occassions and has had all the relevant components changed including the amp and speakers. Their "master" technician eventually said that they weren't very good in my model and he recommended getting an after sale solution..I had all the software updated but still the same, got bored with complaining so now put up with it...I have also tried various inputs but no joy......sorry I need more help than most...sorry !! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I love my HD system. No complaints.
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 41 ![]() ![]() ![]() |
Bumping this thread.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Mine has the HK system in it and you can get colossal volume out of it with very firm gut wrenching Bass notes. BMW i3 Electric Car
Try turning the Logic 7 off. It’s loads better. 2011 Range Rover Vogue SE 4.4 TDV8
I've tried that too with the only result that everything sounds more "flat" and definitely not more punch to it. |
Hozza12163 Member Since: 10 Sep 2019 Location: Bedford Posts: 51 ![]() ![]() ![]() |
Just tried my 2010 Logik 7 on and off and tbf I think it's better with it off. More punchy bass and crisper all over, Logic 7 on is definitely wider but less punchy. It's a subtle difference FFRR
ikjos sounds like an amp issue to me.
No, I don't have the IIDTool (yet). And yes it's probably the amp. Does any of you have experience with those? Just to throw away and find a replacement? Any after market ones that would fit? |
WdeRave Member Since: 25 Apr 2019 Location: Javea, Alicante Posts: 17 ![]() ![]() ![]() |
My Range has the Logic7 HD and the sound is amazing. Have some R&B and you expect the roof to be blown away.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Why add Bluetooth when you can just connect a iPod?
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Or with the Bovee have full access to your playlists etc without having to handle you phone nor plug anything in. |
Sorry guys, Android over iOS .... |
